Andrew, unfrotunately no I can't get you a key :D I was one of the first 2000 to activate my beta key when Kane's Wrath was released, hence how I got in. You are welcome to come round for a gander if you wish... Might even be able to hook you up with my key for you to play, so long as you aren't on when I want to get on :worship:
Managed to become part of the Red Alert 3 beta for anyone who cares. Pretty fun and the whole naval base building adds a whole new twist to things, pretty good so far IMO
ey mate yea i got in to, havnt started playin yet have been busy building some computers for people. Hopefully get onto it on the weekend. How is it any good??
guys what do you think of this build??
i've had my pc for over 3 years now and i think it's time for an upgrade. i figure i'll keep the same case, burner, keyboard, mouse, and probably move a hdd over.
please tell me asap as i'll go pick it up from all needs in the morning.
GA-EP45-DS4P $191
INTEL E8500 $210
WD WD6400KS 640 GB $94
cORSAIR TWIN2X4096-6400c5 4GB $139
Thermaltake TR2 RX 550W $97
Gigabyte HD4870 512mb $366
ohh also am i able to take my current vista home premium OEM and install in on the new pc without any hassles? what i mean is will it still activate as it's a totally different pc or will it be all good?
thanks.
GA-EP45-DS4P $191
INTEL E8500 $210
thanks.
parts are fine , only thing id change is the PSU , get a corsair HX620 , better quality and it is modular
GA-EP45-DS4P $191
INTEL E8500 $210
Nice setup apart from the PSU.
Corsair or Seasonic PSU. They are the same thing.
The 640AAKS is a very quick drive. :blink:
Hmm went and bought it all on Saturday along with a 21.6 inch samsung monitor.
Awesome setup love it.
Also decided to get two of the hdd and am running them in RAID0 muhhaahaha so fast.
On the case of the power supply it is modular, and it seems to have more than enough juice for everything so far.
Crysis at 1650x1080 everything set to "High" and i get a constant framerate of 45-50.
^^^ That's an awesome rig you've put together, it's near identical to mine :)
GA-EP45-DS3R
Intel C2D E8400
Seagate 7200.11 500GB+750GB
OCZ Platinum 8500 (1066Mhz) 4GB
Seasonic S12+ 650W PSU
Nvidia GB 8800GS -> soon to be HD4870 of some sort
im running this on my desktop... got a couple others about but this one is slightly moar interesting
GA-M56S-S3
AMD X2 6000+
Kingston 1G 800 (four of em)
Gigabyte 8800gt (512)
WD 1TB 7200 (got three of em)
WD Raptor 150G (bootdrive)
Antec Neo Power 550W
also have two LG W2252TQ's (22" widescreen 2ms)
gonna get better ram next
any suggestions?
Sticking with the stock frequencies for your mobo - kralster's Corsair TWIN2x4096-6400C5 PRO 4GB would be an obvious choice or OCZ Platinum-PC2 6400 4GB (2x2GB). Also, both should have reasonable potential if you plan to OC.
cheers, i'm leaning towards corsair... probably not gonna OC it, just gonna leave it stock and stable
hey everyone, im going to upgrade my ram in the next couple of days and im after some advice. currently it has 2 512MB PC3200 sticks in it. im debating whether or not to just put another 2 in there to get 2 gig of total RAM or swap them all out for single 1gig sticks so i have a total of 4 gig of RAM.
now my FSB is 800Mhz so what are the advantages of upgrading to a higher speed ram as well?
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
