Usually 2 sticks are marginally quicker & puts less strain than using 4 slots of equivalent memory. Personally, I’d go with any 2GB kit (2x1GB), doubt you’d regularly utilise more than 3GB of memory with your current system.
With the exception of overclocking, there's no real benefit going with faster RAM frequency than what your mobo can support or CPU FSB & in your case that's 400Mhz (assuming you have DDR2 & P4 or better). Although, RAM is quite cheap now so there’s no harm in getting the best 4GB (2x2GB) you can afford, as they are backwards [frequency] compatible & you can always use it in your next system - provided AMD mobo’s don’t also start pushing for DDR3 to become mainstream anytime soon :P.
No madaz it will not.
Your best choice for gaming with a controller on both 360 and PC is to buy a microsoft WIRED xbox360 controller. They are a great controller and work really well on PC.
You can buy the wireless xbox360 controller but then you will also need the wireless receiver.
pkblade when u getting ya 4870???
Finally got it on Tues :D ...went with the MSI's OC version, pretty happy with it so far. Although while I was DL the latest driver I noticed MSI have already released the HD4870X2 OC :). Might wait for prices to go down, currently they're priced $650-750.
So who uses VoIP?
I've been with MyNetFone for quite some time now and really can't fault their service.
Signed up via the MyNetFone whingepool/whirlpool offer. $4.95 per month for 60 free national calls untimed then 10c untimed national and 15c per minute per second billing.
We don't use the phone a great deal but still manage to save a good $80 per month as we often make national and mobile calls.
I'm on the Home Line Budget $19.95 Helstra plan with ADSL2+ from Internode.
For those that are shopping ensure you run a quick traceroute to the sip server you are looking at to ensure the routing isn't stupid from where you are located.
MyNetFone from Internode in Adelaide is ~40ms away with a traceroute you couldn't improve.
Don't buy an ATA device that plugs in to your modem as a lot of modems suffer what is known as a NAT bug; splash out another $40 or so and buy an All in one modem/router/wireless/voip box.
Preferably a billion 740x as they work well and are easy to configure.
i used to use engin for VoIP... service was ok but they were bastards when i went to cancel (having worked in a cancellations call queue with a major ISP i I know whats what with T's & C's, i got his TL on the phone and gave em what for hehhe the dude was highlighted for a "coaching opportunity" LOL ).
I'm also on node adsl2+ wit homeline plus
i had a free zyxel ata that i procured from work.... the GUI is completely counter-intuative on those things
did get delays tho, i tested it bay haveing a mobile fone convo at the same time... it was noticeable
yeah nice work Nick - I remember seeing some of your earlier work on those models and even then they looked the bomb!
Hey Bezender - you need one or 2 of these:
Dual external hard drive case (click)
Benefits
Inbuilt fan - my HDDs stay even cooler than they used to when inside my Matrix VX
Its own power supply
Can take the SuperBox with you and connect it up at a mates place with dual E-Sata for speedy data sharing
One or two of these might be in order too (click)
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
