But at home, I'm on that pair gain system, so I connect at 31.2kbps :P
I've argued with Telstra many, many times to get relocations, 2nd line installed and even thought about plowing a cheap bomb of a car into the local Exchange so it gets upgraded (as there's no spare spots on it to even get me off the system!) but nothing has worked.
So at home, I'm stuck on dial-up. No cable access, either. And ISDN is too expensive, and Wireless is a joke.
kelly Molly, PK?
Steve, Telstra simply wont touch it! I used to work for Kaz, and when I mentioned I was with them, they seemed to change their tune! But apparently it's just not possible and they've said "wait 5 years and then talk to us"
Hahahaha 5 years and I'll be out of that place! Or in 5 years, we'd all be running Fibre :P
SLED.. Pings - In this instance it depends on interleaving/error correction placed on he line.
Typically higher speed profiles that push the usable spectrum to the limit employ greater error correction/interleaving as a result pings increase.
An ADSL line profile essentially employs a given interleaving and target SNR.
so what you're saying is that if I log into my provider and up my speed, I'll increase the ping count but make it less stable.
I upped the speed awhile ago but kept dropping out so went back to standard.
I'm on Recommended at the moment and seems pretty stable:
What do the different Profiles Mean?
The following are the semi-technical terms for each of the Performance Profiles:
Conservative
  • Can achieve speeds up to 4 Mbits/sec (~435kB/sec) but designed to sacrifice speed for rock solid connections. Used to support phone lines with poor Signal to Noise Ratios (SNR) and/or long distances from the Exchange.
Resilient
  • Can achieve speeds up to 8 Mbits/sec (~870kB/sec) and builds on the checks used for the Conservative setting. Useful for customers who have consistent dropouts or Cyclic Redundancy Check (CRC) errors. Can provide the most stable connection out of all the performance profiles.
Recommended
  • Can achieve speeds up to 8 Mbits/sec (~870kB/sec). Provided as the default configuration for all AdamDirect services. This ensures backwards compatibility for ADSL 1 capable modems. A robust setting that is good for the majority of customers connected to an AdamDirect Service, regardless of distance and minor variances in SNR.
Aggressive
  • Can achieve speeds up to 12 Mbits/sec (~1306kB/sec). This setting provides for high speed connectivity. Suitable for latest generation ADSL2/2+ capable modems. This setting may be useful for short to medium length distances from the Exchange.
Adventurous
  • Can achieve speeds up to 24 Mbits/sec (~2611kB/sec). Full speed capability is available using this profile. Your line quality should be of a high standard with a strong signal strength. We recommend attempting this setting if you have maintained a successful connection using the Aggressive profile for a period of time.
Thrillseeker
  • Can achieve speeds up to 24 Mbits/sec (~2611kB/sec). This is an Adventurous setting with a twist: interleaving is turned off. Interleaving is a process of error control that sends data to your modem in a non contiguous fashion. This tends to provide a more error tolerant connection. Some customers would choose this profile to decrease gaming "ping" times. This profile is not recommended for general use.
Typically running a line profile that aims to provide increased 'bandwidth' will target a lower SNR ~6db and increase interleaving that will increase ping/latency.
Depending on the ISP profiles can be configured any way they feel fit.
Typically there's 2 area's to consider. + the technology.. ADSL1 and ADSL2+
Interleaving and SNR target. SNR target determines the speed.
The Interleaving determines the stability/reliability to some extent. As you know increasing interleaving increases ping/latency.
Low SNR with no latency is the ultimate but only if you are close to the exchange, no bridge taps, internal wiring is spot on and no interference.
The Recommended profile appears to be an ADSL1 based profile.
If you experience dropouts with an ADSL2+ profile this is due to interference within the frequency range ADSL2+ uses. ADSL2/2+ uses a greater range of the available frequency to obtain the faster speeds over adsl1.
By you selecting the ADSL1 profile you are not using the frequency that suffers interference as a result your connection is stable.
Not much you can do about it apart from making sure your internal wiring is spot on and a central splitter is fitted.
I've found longer distances you can squeeze a little more out of your connection by locking it down to ADSL2 only mode (not 2+). 2+ doesn't work too well on long lines.
a mate of mine works for a hosting company who have 4 dark fibre links that are load balenced
/dribble
basically 4 x 10Gb fibre links.... on the small portion of bandwith that he is allowed in his department he gets 78000+kb/s
he even is allowed to ave a PC in a rack there that can get 600kb/s with no d/l limit
im jealous
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
