i ran suse once looked nice but im too noob to know how to run linux pity it isn't made more like some other broken piece of software some of us embrace
i double dare you to use slackware or FreeBSD :P
-D
finally got round to installing the lanparty x48 mobo
only board Ive ever run that installed everything, running with drivers, 1st go off the bat.
had to update bios (as you should) to recognise an updated-bios 3870X2 card due to the -2on1- display setup
(run the 3870x2 with the 'asus top' bios setup 851/954mhz setup ~ 6% stable gain in performance just from bios update)
very very nice board.
LanParty LT x48-TR2
Intel QX6850 quadcore 3.0ghz CPU
Asus Lion Square cpu cooler
Asus 3870x2 1gb Video Card
3gb Patriot 1066mhz ddr2 Ram
Thermaltake ram cooler
Dell PhysX pci card
3x 320gb Sata HD in Raid0
1x 500gb Sata HD backup
Dvd burner, Fdd, Fan & Temp controller, Vista Ulitame 64-bit
Lian Li PC-V2010 huge-m0f0 tower
G5 mouse, G15 key, Logitech X-530 surround sound, Sonar 5.1 usb headset, 22" proview 2ms Lcd
"spare" kids & wife pc with my other board, also have a p5w dh deluxe sitting here, and 2x dead s900XT's that died whilst on water cooling system.
so my choice water system is sitting idle atm. another day.
Asus P5E
Intel Q6600 quadcore 2.4ghz CPU
Thermaltake VX typhoon cpu cooler
MSI o/c Ati 2600xt
4gb OCZ Bronze 667mhz ddr2 Ram
2 x 200gb Sata HD's
Dvd burner, Fdd, Vista, basic case,
Wolf keyboard, Cyber Snipa mouse, Soloman 5.1 sound, Zalman headset, 19" Cmv 5ms Lcd
grrr too much ebay'ing.
moral to the story, keep on upgrading, buy for cheap and sell when upgrading, keeping what you dont flog off over the years as a 2nd good pc.
better do some benchmarks now. had a 3rd 3870 Ati card, new, but onsold that to my brother when he grabbed a 24" screen.
might grab a cheap $80 3850x2 1b tho :happy: just like the Stagea cant stop :)
have i mentioned that i dont like you ? :P
have i mentioned you have a RB26 :D
steve whos your internet provider and how much do you pay per month? =]
BP cable extreme 12gb per month :( about $69 with 3 telstra items i am no 1.7gb over my daily limit as per net usage item :rofl:
love your Street Fighter sig Keitz
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
