i ran suse once looked nice but im too noob to know how to run linux pity it isn't made more like some other broken piece of software some of us embrace
i double dare you to use slackware or FreeBSD :P
-D
finally got round to installing the lanparty x48 mobo
only board Ive ever run that installed everything, running with drivers, 1st go off the bat.
had to update bios (as you should) to recognise an updated-bios 3870X2 card due to the -2on1- display setup
(run the 3870x2 with the 'asus top' bios setup 851/954mhz setup ~ 6% stable gain in performance just from bios update)
very very nice board.
LanParty LT x48-TR2
Intel QX6850 quadcore 3.0ghz CPU
Asus Lion Square cpu cooler
Asus 3870x2 1gb Video Card
3gb Patriot 1066mhz ddr2 Ram
Thermaltake ram cooler
Dell PhysX pci card
3x 320gb Sata HD in Raid0
1x 500gb Sata HD backup
Dvd burner, Fdd, Fan & Temp controller, Vista Ulitame 64-bit
Lian Li PC-V2010 huge-m0f0 tower
G5 mouse, G15 key, Logitech X-530 surround sound, Sonar 5.1 usb headset, 22" proview 2ms Lcd
"spare" kids & wife pc with my other board, also have a p5w dh deluxe sitting here, and 2x dead s900XT's that died whilst on water cooling system.
so my choice water system is sitting idle atm. another day.
Asus P5E
Intel Q6600 quadcore 2.4ghz CPU
Thermaltake VX typhoon cpu cooler
MSI o/c Ati 2600xt
4gb OCZ Bronze 667mhz ddr2 Ram
2 x 200gb Sata HD's
Dvd burner, Fdd, Vista, basic case,
Wolf keyboard, Cyber Snipa mouse, Soloman 5.1 sound, Zalman headset, 19" Cmv 5ms Lcd
grrr too much ebay'ing.
moral to the story, keep on upgrading, buy for cheap and sell when upgrading, keeping what you dont flog off over the years as a 2nd good pc.
better do some benchmarks now. had a 3rd 3870 Ati card, new, but onsold that to my brother when he grabbed a 24" screen.
might grab a cheap $80 3850x2 1b tho :happy: just like the Stagea cant stop :)
have i mentioned that i dont like you ? :P
have i mentioned you have a RB26 :D
steve whos your internet provider and how much do you pay per month? =]
BP cable extreme 12gb per month :( about $69 with 3 telstra items i am no 1.7gb over my daily limit as per net usage item :rofl:
love your Street Fighter sig Keitz
    • That is self help. Encouraging others to spend more than me, makes my spending relatively less ridiculous.
    • Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more
    • I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
    • You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
    • Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
