yeah I have just finished installing Windows 7 and it looks very good for a Beta. I am just wondering though - exactly how is it different to Vista? I have found very few differences except for its speed and stability.
better networking :P
hey i hav live for speed s2 and i am wondering how to make the cars sound good like i hav watched it on youtube and ther are some pretty tuff sounding cars on ther, they use patches or some sh*t i dont kno. I am not very computer smart at all (as u can prob tell lol) so i was wondering if any knos how to do it or could help me cheers jarad
Bishop you can do it with a program called LFSTweak, it lets you change then engines to anything from 4 cylinders to turbocharged V12s, can change tyre size and all sorts, some engines sound f**king gay but some sound awesome, the program only works with the latest version of LFS however.
Another way is to use CSR like they did in the video, this program is harder to use and I don't know if its supported any more, however its worth a shot http://www.lfsforum.net/showthread.php?t=12863
Have a browse around on the LFS forum in the addons section, theres a few mods that allow you to change the blow off valve etc as well.
Its rolls, matts friend btw, if you get stuck hit me up on msn [email protected] catcha
Edited by Rolls
Also, has anyone else got a Wii? I bought Wii Fit for the missus for Xmas (I wasn't being rude - she requested it) and just got a game called Family Ski. Being a snow skier it is a very realistic and highly entertaining game! Thoroughly recommended.
So many people in various forums bag Wii Fit as boring and not worth it, but I have been enjoying it since Xmas - an effective way to get off my ass and do some exercise and have a bit of fun while doing it. I have had many 1.5 hour sessions where I can feel afterward that I have had a decent workout (some of the exercises are absolutely brutal) yet the time flew and was fun. Bizarre - I never though I would get into it - but I have used it much more than Carolyn at this point (but I need to whereas she doesn't lol). I have noticed my fitness and coordination has improved in the short time I have had it, so that is encouraging.
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
