Also, has anyone else got a Wii? I bought Wii Fit for the missus for Xmas (I wasn't being rude - she requested it) and just got a game called Family Ski. Being a snow skier it is a very realistic and highly entertaining game! Thoroughly recommended.
So many people in various forums bag Wii Fit as boring and not worth it, but I have been enjoying it since Xmas - an effective way to get off my ass and do some exercise and have a bit of fun while doing it. I have had many 1.5 hour sessions where I can feel afterward that I have had a decent workout (some of the exercises are absolutely brutal) yet the time flew and was fun. Bizarre - I never though I would get into it - but I have used it much more than Carolyn at this point (but I need to whereas she doesn't lol). I have noticed my fitness and coordination has improved in the short time I have had it, so that is encouraging.
i cant find this family ski anywhere??
where did u buy it from
Inhouse LAN dota tonight at arena, anyone interested? :)
yeah yeah~ I know it's "Warcraft 3 shit", and most of the people here plays FPS games, but it's ok! gotta try something new everytime maaaaahhhhhhh~~~ THanx LAAHHHHHHH
anyone have a copy of windows 7 ?
yep, and love it.
If you can be bothered coming out to the 'burbs I can put it on a DVD for you Mitch for you to come and pick up. I live in Northgate
I havent heard much about windows 7 yet.
what I have heard has been good tho.
Im in northfield. one suburb over from you nightcrawler. I go to my parents via Nothgate all the time.
still never spotted each other. strange.
i downloaded this morning took about 15 mins ;)goto love extreme cable
lol, you're extreme mate! :)
yep, and love it.
is it leaps & bounds better than XP Andrew.........also is it very buggy, or fairly well ironed out?
yep, and love it.
cheers for the offer but im getting it off a mate down the road :)
It is very well sorted Pete. I haven't used it as my daily PC, but have mucked around a fair bit and haven't managed to break it. It basically is what Vista should have been and is quite similar. It is currently stable as.
The biggest revelation is the speed - I have it installed on a spare crappy AMD Sempron 3000 with 1Gb of ram and it runs very sweet indeed. Would no doubt blitz on my quad core Phenom, but I already have a dual boot setup and would not be game to break it with a triple boot scenario.
If you want a copy let me know, but you will need to register with MS for a key (easy to do).
you got a link ?
also , what drivers will i have to use for my creative x-fi to get sound on w7 ?
or will it automatically apply its own drivers ?
will it pick up my 4gb of ram or just the usual 3.25gb like 32bit os
cheers
you got a link ?
cheers
I am running a copy of Windows 7 in VMware under Vista x64. Runs really well with 1gb assigned.
If you want to use the full 4gb simply download Windows 7 x64 :banana:
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
