I am running a copy of Windows 7 in VMware under Vista x64. Runs really well with 1gb assigned.
If you want to use the full 4gb simply download Windows 7 x64 :banana:
hows the driver situation for x64 these days? I installed x64 xp pro 4 years ago and was annoyed that a load of stuff didnt have drivers (and i have reasonably modern hardware).... i switched back to 32 bit 2 days later and havent touched it since, however i will be upgrading in a few months time and its worth thinking about
-D
-D
Now issues. Now. :laugh: But as with everything it depends on the hardware. Mines a fairly basic setup. Intel cpu, intel chipset m/board, nvidia 8x vid card, 2 large hard drives, dvdrom for the Wii and a nice pioneer burner.
Windows is rock solid I don't have any issues with games programs.
Like yourself when it was first released pre-sp1 I tried x64 and it was crap, wasn't too keen on vista x86 back then due to 2gb not running all that flash when you throw a decent game and vmware at it so I dropped back to XP. Sp1 came around and decided to install x64; felt slow so threw another 2 gb at it.
x64 does need 4gb other wise it feels a little chuggy.
Running 2gb with vista felt slower than xp with 2gb. Vista with 4gb is noticeably snappier than xp.
Im looking at getting a laptop soon for nistune ecu tune, internet, gaming and watching dvd's. Iv hade a look around and most places i go to say Acer is the brand to go with, is this true?
Dave
I wouldn't say so, few family members own then, they're pretty dodgey. Toshiba make some nice cheap ones, and asus laptops aren't too bad.
Cheers for that iv herd the same about Acer aswell just wasnt sure if it was true. I just rang same places and they have toshibia laptops starting from $1100 so il go see and hopfuly i come back with somthing.
I got the toshiba satellite A300
15.4 screen
Vista
Intel® Core2 Duo P7450@ 2.13GHz
2.00 GB
selling price was $1799 but got them down to $1699 with a Belkin case and belkin cordless mouse
$200 over the budget but still pretty happy
at work we use:
Desktops: HP7800's...core 2, 2 GB RAM, 180GB HDD and i reackon they are awesome units
Laptops: Dell Lattitude D830....core 2, 2GB RAM 120GB HDD...slightly heavy laptop but doesnt give any hassles
just thought i would put it out there u knw
Dave
I have an Asus EEE 901 for that exact purpose - works excellent. Need a bigger SSD but thats coming soon... theyre dead cheap too and fit in the glovebox
-D
i am a big fan of those eeepc's
if your are student then they are perfect
compact in size and are not too bad in performace
with just the basics
I've only encountered two minor issues. One is the size of the primary SSD (4gb) and the other is the speed of the secondary (either 8 or 16gb depending if u get the linux or windows version).
I ran out of space for my windows install on the 4gb and have software which needs to be ran off the boot drive. When I switched it to the 8gb ssd, the SSD was just too damn slow (the write times are 3-4 times as long which makes all the difference)...
So I've put Fedora 10 on the 4gb, XP is on the 8gb and I'll be getting a runcore 32gb m-pci SSD to replace the 8 gigger. They actually make very fast SSD's, faster than the stock 4gb unit. Couple that with the 2 gigs of ram I've put in there, and it should fly.
Unit works beautifully with my bluetooth mouse and nextG bluetooth phone as a modem. Runs fedora with compiz fusion very very nicely and has around 4.5 hours of battery life at constant use. I've managed to make mine last all day by changing the APCI settings.
It also fits in the r32 glovebox, which is where I have the consult port and 12v power to the laptop wired. Makes it very very easy to port around as it gets charged in the glovebox when I'm driving...
-D
i was thinking of making a custom glove box setup with the eeepc controlling my audio / video and the rest
would be a mental setup as i could have the glove box open and use the eepc and shit like that
Those are the first generation 701's. They arent good value for money. They have a 7" screen and a paltry 800mhz CPU.
The 901's were the first to bring in the Intel Atom chipset - Dual core 1.6ghz with integrated 945 chipset for video (it complies with vista's rendering standards). The 901's also have more battery life and a 9" screen, and some versions are coming out soon with integrated HSDPA (Next G data) modems built into them.
Krishy, it wouldn't work nicely for AV, esp not in the glovebox - if you want to do that, a carputer is still the best option, esp if you get it with an in-dash touchscreen.... EEE's are great for what they are, but they still have undersized keyboards which give most people hassles, and I'm sorry to say that the trackpad isnt great either - which was the main reason I bought the bluetooth mouse...
They also have the ability to run the EEE-TV usb DVT-B digital tuner - I've got one and it works great, provided you're in range and have a decent antenna...
Personally, I wouldn't buy anything without the Intel Atom chipset... the 901 isnt slow, but you wouldnt want to go much slower - esp if you don't intend on replacing the secondary SSD with a faster replacement.
-D
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
