this is a bit diff to what i thought, but easier to manage whilst vehicle is in motion i would believe
http://cgi.ebay.com.au/Asus-EEEPC-Solderle...%3A1|240%3A1318
Can you get an external HDD for these, or am i missing the link between HDD and SSD
it has usb ports so you can get external hdd's but you dont want a hdd in the car due to g-forces and shock. ssd = solid state (no moving parts) and can tolerate a lot of shock. They also draw about 1 watt as opposed to the 12-20 watts of a laptop (2.5") hdd - thats one of the reasons the netbooks can get 4 hours of use. Some of them use standard hdd's on the 1.8" scale but these too still draw a lot of power.
That link is for putting the perspect touch sensor inside an existing 901 laptop screen - loads of people have been doing this but I think this is the first one I've seen which doesn't require soldering. SO very tempting, tho it would void my warranty....
-D
OK all you 4 eyed geeks out there ;)
I need to get serious about another build using decent gear without going over the top with price.
Input would be needed and appreciated.....here's a start:
Gigabyte EP45-UD3P M/Board...................$220
Intel Q9550 2.83Mhz CPU........................$413
Corsair Dominator DDR II 1066Mhz 4Gb.......$170
ATi Radeon HD 4850 1Gb.........................$280
Thermaltake 650W 'Q' Fan PSU.................$175
Samsung 2333 SW 23" LCD......................$290
Don't pay tax so these are all EX prices.......anyone do any better or suggest different setup?
Used for office work & video editing.........hence I normally run a Stripe Raid setup.
G-B EX58 DS4....................................$339
i& 920...............................................$469
4GB Kit(2x2G)DDR2 1066 Kingston.......$95
1GB 4850 Gigabyte.............................$287
Thermaltake ToughPower 600W...........$140
monitor personally im looking at this
21.5 “ 2ms HD WS Benq E2200HD Full HD.....$238
i was pretty sure not 100% sure just pretty that i7 uses either
all prices Inc. tax
this is what my mate gets at work
he gets to have a server on a 100Mb link to it too that he can just use to whore on torrents
/jealous
Weird - maximum I've gotten at Hostworks was about 70mbps on speedtest.net ;) .. That said, it does seem to depend on the time of day which suggests it may be a limitation of the testing server rather than Hostworks' connectivity though ...
I would be also be very careful of your friend advertising he 'whores torrents' on this server :)
sorry your right but for a little more than the dominator ram get some Gskill
4G Kit(2x2G) DDR3 1333 G.Skill NQ..............$215
you not going to overclock so you dont need heaps fancy ram Gskill will be quite fine
Steve, just checked out that GB EX58, it's 3 way, so would need 3 x 2Gb which may get expensive to go the i7 route.
Curious to know what the 1600mhz would cost?
Does your supplier issue proper tax invoices?.......otherwise no point if I can't claim the tax back.
Also the 600W ToughPower is noisy compared to the 650W 'Q' I think.
Hi Pete
almost the same as my setup except i run a 4870 vid card and asus m/board
i've had the 9550 running 3.0 ghz on air cooler for 6 months and it is magic!
I would go for a coolermaster tru power psu that has 5 year warranty
G.Skill NQ 3x2Gb DDR3 1600mhz = ~$377(excl gst) and yes his supplier does issue non-dodgy tax invoices :huh:
that's good to know Adrian......because of work files & video work I won't be overclocking as I need it to run very cool & rock stable.
I know Antec also offer 5 yr warranty but apparently Thermaltake have just gone Life-Time?!
Haha, thanks for that Patrick.....problem with DDR3 is that it's still too dear compared to DDR2 so I have to decide whether to spend the extra $$ although the i7 over the Q9550 would be very nice.
Haha, thanks for that Patrick.....problem with DDR3 is that it's still too dear compared to DDR2 so I have to decide whether to spend the extra $ although the i7 over the Q9550 would be very nice.
Unless you're running games, databases or doing hardcore rendering, its a waste. Stick with a quad core system and dual core ddr2, you'll get better value for that.
Incidentally re: EEE pc's, theres a new one coming out from Nvidia which replaces the i945 graphics chip with a 9300gm 3d accelerated northbridge.
Meaning the gfx card wont be neutered and will actually render HD properly. Interesting to note that they will keep the intel atom processor as the CPU, and that the 9300GM has integrated Phys-x capability (tho I cant see many games that use phys-x running nicely on the 9300, even tho it IS a step up).
I'll be keeping an eye out. Any excuse to put World of Warcraft on a netbook and run it across nextG is a good one. :huh:
-D
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
