  Madaz said:
interesting Matthew that the Q6600 with less speed still beats the newer CPU with more speed so one might guess its all the cache the Q6600 has
yeah i might uninstall FF
I would agree.. the old AMD budget cpus were full fledged rigs just minus cache and limited them severely. I spose yours being quad core and mine being dual your advantage in the memory stakes is cache.
BTW I just ran 3dmark06 with it at 4ghz as on the previous everest stats and improved the score to 16423 not a bad jump for no money.
  Madaz said:
nice what gfx is that with
Thats with an ATI 4870 512.. almost bought a 4870 x2 on sunday to add to it but really need to buy those coil packs lol.. stag come first... sometimes.
That 4ghz is on air cooling too... mind you it only just squeezes into the case height wise
Edited by Stagstock
ah nice i just booted back into win7 and FF works :D
running @ 3.4ghz benched 3d mark 06 and score another 2k on previous score, took a few goes to get it to book properly had to lower the FSB each time
>>14278 ORB<<
super Pi not that much different @ 15.332 Checksum: 01D34DA9
will edit with CSS frames
CSS saw a healthy jump in FPS from
Pass 2 251.98 - fps_max 400
Pass 3 256.88 - fps_max 600
Pass 4 244.08 - firefox open in the back ground
TOO
Pass 1 276.68 - fps_max 700
Pass 2 277.29 - fps_max 700
  typevu said:
I cant get 3DMark06 to work... it just doesnt get past the loading screen. Updated graphics card drivers to latest and still nothing.
Weird - mine too! Exact same problem
  Madaz said:
Play with the DRAM:FSB ratio (should be called 'Strap' in BIOS) so you can push your memory bus up without affecting the CPU speed or actual FSB because it only affects the memory bus. It will bench much harder :(
What's your GPU clock & memory clock cos the score looks higher than norm for stock HD4870 512Mb (ie. 750Mhz/900Mhz)
Nice job...now run Linpack to see how stable it is :(
I might get back to O/C since winter is arriving...in summer I managed the E8400 (E0) @ 4.46ghz (496x9) with 1.49vcore aircooled, any higher it would crash if I tried starting up in standby mode. Also, main restriction is the mobo as it struggles to handle FSB higher than 525-530 so theoretically ~4.8Ghz (530x9) would be it's limit.
The beauty of the dual cores :) 525-530 is f**kin' decent, what motherboard?
My Q6600 hits FSB wall at around 460-470FSB even when I drop the multiplier to 7 :D I think the sweet spot for the Q6600's is multiplier at 8 and use the CPU Strap to raise the memory bus.
Yeah the Wolfdale processor are great that way. mobo is a Gigabyte EP45 DS3R, performs almost on par with the EP45-extreme and only lacks the bigger NB and SB heatsinks.
Can't believe even after 2+yrs when it comes to o/c and performance the Q6600 is still prob one of the best bang for your $$.
Those P45 boards were great value. So long as you keep air flowing over those heatsinks you shouldn't have a problem..... I hope Gigabyte did a better job of mounting those heatsinks than ASUS did on mine!!!
One day I'll pull my NB/SB heatsinks and reseat them, probably my only gripe with my Maximus Formula SE board I must admit.
  pkblade said:
Air flow is no problem, have the HAF 932 w/ hi-flow aftermarket fans
Same, airflow not a problem. I have Noctua NF-P12 fans in my Silverstone TJ09 case and everything is fine even whilst OC'ed except the NB/SB.
Speaking of Q6600s
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=270385607480
And while I am shamelessly plugging my Habibay auctions, anyone want a nice PCI-e 7600GT?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=270385625022
I will have a PCI-e Asus EAH3850 256Mb DDR3 Video card $120 for sale shortly too if anyone has an eoi.
I will also shortly have a 320Gb WD SATA HDD $40, 400Gb WD SATA HDD $50 and a 500Gb WD SATA HDD $60 for sale soon if anyone wants some storage.
  Madaz said:
what you mean when i comes out tomorrow Helso already has it
i too had one of the early versions of the RC, got it on april 2.
there is a newer publicly available RC out now on the m$oft website
whats that FF add-on that saves all ur other add-ons to a remote server?
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
