SSD any news on price drops ??
http://www.pccasegear.com/index.php?main_p...oducts_id=10933
$329 on a 60gb, thats a fair bit cheaper than what it was 3 months ago. I'll wait another 6 months till my beta version of w7 expires and then I'll get the SSD and w7 home
-D
yeah still a tad too rich for me
i would rather a 5850 for around that money than a bit quicker hdd
depends on what your aim is. if you're not gaming, an SSD makes a hell of a lot of difference
my eee 901 now boots faster than my i7 920 - the 901 has 2gigs, the i7 has 12 gigs... but the difference between the hdd's is a good minute, and thats with the inferior hardware booting off the ssd and winning...
wait till they come down to $200 for 60gigs, give it 6 months or so :D
-D
Yes and No...Yes to Playing MW2, No to playing on PS3, shall be on PC.
:thumbsup:
Shall also be playing on pc, along with working on patching my ... "disabled" copy of mw2 so it has multi again.
Just found out about this, sounds awesome: http://www.moddb.com/mods/gta-united
  • 3 weeks later...
What are your steam names for CODmw2 ? Real nice game.
Also damo. Add 'barik' for the ps3. My mates account. He is pro, but Ill head over sometimes and play. Im hopeless on ps3
Steam account name is :Xer0c00l
I dont play games very often any more, and when i do, mostly co-op.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
