its in all the use of joining words some say schematics
i said used to be in its hey day which makes the statement correct
you use the words
dos 6.2 is a totally awesome....
where if you used was then that statement would also be correct
Has anyone tried Facebook Lite? I actually prefer it to the normal Facebook because it runs more like a normal website, as it cuts out a lot of the unnecessary AJAX crap that slows down the site. It's accessible at http://lite.facebook.com
just about to get new broadband at home..
is 20gb p/m enough if i want to smash online play on my ps3?
and should i go adsl2+ or adsl?
any recommendations?
20 gigs should be more than enough. Try Adam Internet ADSL2+, works well here, and you get 20 gig in peak hours (8am-midnight) and an extra 20 gig off-peak (midnight-8am). Cost is about $55/month AFAIK.
also why internode over adam?
if you want quantity = adam
if you want quality = internode
101% internode, been a customer for 8 yrs and have had less than a handfull of issues over that time. excellent service and support. what more can one want?
-D
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
