Yeah they use geforce quadro's for cad at my work. Pretty good cards for rendering 3d models in complex detail. Not good for gaming ;P
-D
Not to mention pricey, last time I looked...about 6 months ago, they were around the $1k mark or higher.
-D
What CAD systems are they using?
It will be used for predominantly CAM applications, Edgecam to be specific. With a bit of CATIA and SolidWorks thrown in for good measure. Tool-path verification will be what i need the graphics power for. Unless it is coded to support some GPU computing, which I doubt.
Is it worth going for a workstation card even if the program isn't specifically supported with drivers? Or would I be better off spending the same coin on a gaming card which will have more brute power, however not as fine tuned?
anyone got a decent computer for sale cheap ??
i have a barebones chassis (case + motherboard, u would have to get the rest) in my cupboard that i'd happily part with. had big plans but went in another direction.
lemme kno if u want more details /pics etc
Heaps. Wonderware, Autocad, Altium Designer, etc...
Depends on the software - I'd check with the manufacturer. No point spending $1k on a card that the software cant use.
-D
500 just the tower i got monitior wanted for some vidoe editing nothin spectacular and just crusing the net
glad to see you bought only what you needed
many people get sucked in
count yourself as not one of them ;)
-D
I asked Adam a few weeks ago to change my Internet Plan to their new plans - AdamBasicChoice 100GB, which is up to 20Mbps.
So my account rolled over the other day, and I hadn't received my extra speed - was a little pissed, so I sent them an email, and they replied saying it was going to take 3-5 days, as the wholesaler still had to apply my upgrade.
Well, I got home today from Balgowan, checked my speed, and I am rather happy with it :)
Had torrents going at the time, but I am not going to complain.
If your with Adam make sure you up your connection profile. I've got a SNR of 6 and run stable on their second to fastest profile. I sure noticed the difference over standard.
I have no idea how to do that, but with my modem - Billion 7300GRA with Autodetect settings, I get this
You've also got to watch the error correction, speed and snr often look good on higher profiles but a good chunk of speed can be lost to correction on not so good lines.
If you're on an Adam dslam, jump on the members page and go to 'View Performance Profile'
Nope, don't have that option. Most likely as I am on ADSL not on ADSL2+, even though my modem is using the ADSL2+ protocol to sync...meh, I am happy with the results - downloaded 1.4gb in 10-20min :)
Sure it's not ADSL2+ over a telstra dslam?
"ADSL" will get you 8mbit/1 and "ADSL over POTS G.992.1" 12mbit/1.3 under perfect line conditions.
Adam can still tweak the line profile, but you've got to call up to get it done.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
