Yeah I run my Quad core AMD 965 @ 3.825Ghz all day every day (it was 3.4Ghz stock) - but I have taken it to 4.3Ghz (it is water cooled) ... temps went a bit high when playing Crysis 2 at full res though, so turned it down. TBH the performance benefit of 4.3Ghz over 3.825Ghz is negligible anyhow. And my dual 64Gb SSDs are not a choking point either.
I've sent my OCZ revodrive back. Kept corrupting the partition every time it would shut down. Something seriously wrong there. Hopefully they give me an upgrade once its verified faulty
-D
Wow that sucks Ben. I seriously thought about buying one for a decent clients machine I was building around that time, but ended up erring on the side of caution. The lack of TRIM support had me worried.
Hope yours gets replaced with the upgraded version with TRIM and idle garbage collection support.
I had a 200Gb A-Ram SSD with Sandforce Controller that shit itself after 10 mths in my office machine....................they've got a long way to go with these new drives cause I've never had a SATA or even an Eide drive die on me since Win95 1st Edition
This one doesn't have anything to do with TRIM or the garbage collection
Rather, its still writing data when the motherboard powers down - either the drive or Win7's handling of the shutdown procedure is bunk.
The x2 drives are a significant improvement - theyre also significantly more expensive. I doubt I'll be given one of those
-D
You don't want to stripe, if one goes you'll lose both, doubling your chance of failure. Mirror with 2 disks or RAID5 with three disks is good for backups, both options have 1 disk of redundancy with RAID5 giving a performance increase. Raid0 is only for going fast and for anything you don't want to keep.
If your data is really important, get a docking station for a HDD and back up onto a 2TB drive and then unplug it and put it in your safe. Raid is good if a disk dies but if you get a virus or accidentally delete something you're still screwed. Having the drive unplugged also protects you from stuff like power surges, theft and system malfunction.
striping is fine for operating system data, esp when you have the MBTF of a modern SSD
Eg Revodrives are internally raid 0 to get their 540MB per second reads
-D
All good points, personally what I would do is if you don't have a huge amount of important data to back up is do this.
Stripe 2 or 3 High performance disks together, and then have another 2Tb backup drive. Now you could mirror to the 2TB, but most the time half your data you don't care about, so do what I do and every night backup all your documents and settings folder, desktop, my docs and any other important data etc. That way if you lose a disk you just format and copy your data back. If you can afford it do a mirror as well but often it is unnecessary. I don't run a stripe, but I do the same thing in principle with my drives.
I have about 5 disks, I backup everything important from one disk to another disk each night, assuming I only get one disk failing at any time, I don't lose any data. I also backup to dropbox, and then via dropbox to my work PC.
Edited by Rolls
  • 1 month later...
hey guys, good to see this thread is somewhat still active.
Kralster get back from E3 trip? How was it, I watched it live and thinking about going there next year.
And have any of you guys heard about the new tech scheduled for later this year from AMD and ATI? I am building a PC around october and still unsure whether to grab a 590 or 2x580s and have not heard anything ATI has to offer.
That guy is still around? :blink:
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
