why dont you put Windows 7 Enterprise on it with a 90 day free trial with internet activation that will give you more than enough time to do what you need to in a better environment than vista
http://technet.microsoft.com/en-us/evalcenter/cc442495
QFT. Vista sucks.
-D
Would love too upgrade it but can't.
I've been trying to use my own laptop with Windows 7 on it for some of the work and it just doesn't communicate well enough with our other computers and sensors in the unit as they aren't programed for it.
My work is f**king retarted to even be using Vista as only XP and 2000 have been tested proporly with our equipment and proven to work.
Think I might have sorted it out though.
  • 4 weeks later...
My internet has been playing up tonight somewhat (but was working through the period below) .... not sure if my internet disconnections are an Adam Wimax issue or what ... but checking through my modem log I came across these:
Thursday, 15 December 2011 9:04:04 PM Blocked access attempt from 212.34.104.8:1706 to TCP port 445
Thursday, 15 December 2011 9:04:06 PM Blocked access attempt from 212.34.104.8:1706 to TCP port 445
Thursday, 15 December 2011 9:05:54 PM Blocked access attempt from 84.237.162.93:4574 to TCP port 445
Thursday, 15 December 2011 9:05:57 PM Blocked access attempt from 84.237.162.93:4574 to TCP port 445
Thursday, 15 December 2011 9:08:46 PM Blocked access attempt from 222.189.238.115:6000 to TCP port 3306
Thursday, 15 December 2011 9:10:32 PM Blocked access attempt from 94.67.201.65:1040 to TCP port 445
Thursday, 15 December 2011 9:10:35 PM Blocked access attempt from 94.67.201.65:1040 to TCP port 445
Thursday, 15 December 2011 9:16:37 PM Blocked access attempt from 90.156.201.106:80 to TCP port 2386
Thursday, 15 December 2011 9:16:40 PM Blocked access attempt from 90.156.201.106:80 to TCP port 2386
Thursday, 15 December 2011 9:18:24 PM Blocked access attempt from 208.248.77.132:80 to TCP port 48623
Thursday, 15 December 2011 9:22:41 PM Blocked access attempt from 60.172.22.77:6000 to TCP port 1433
Thursday, 15 December 2011 9:24:34 PM Blocked access attempt from 187.59.151.131:4638 to TCP port 23
Is this normal, or is someone tring to hack me? And no, I had no Torrents or anything downloading at the time.
<snip>
Thats a distributed denial of service attack (DDoS) - your firewall is doing the right thing in blocking it.
Mind you your firewall is only catching a portion of them. Looking at the port numbers indicates they're fishing for weaknesses so the firewall is only going to notice any ports its setup to notice. Its not uncommon to be randomly probed by many hosts on all ports from 0-65536 or whatever the upper level is
-D
Thanks Ben, that's what I thought.
BUT, I have rebooted my modem around 6 times tonight, so (I presume - I haven't kept an eye on it) my Adam-assigned IP keeps changing - how would they know to keep attacking me when my IP changes? I had a look and those IPs are from all over the place, Taiwan, Costa rice, Russia .... I assume they got my IP from downloading Torrents, but like I said my IP with Adam is not static, and changes all the time .....
it could be based upon other things, such as mac addresses, or if you have a trojan that reports your ip the same way dyndns does. What you need to do is install a packet sniffer and capture all the traffic ur eth0 adapter puts out from the time its initialized and check to see what packets are being sent back to the above ips as well as filter it via your mac address/adresses (mac address of NIC on mobo is diff to mac addy on your TA aka the adsl modem/cable modem - all depends upon which layer its getting filtered)
First check is download spybot, adaware, their updates and avast. remove and reinstall your firewall/av, install spyware/adaware, run scans, clean, install avast, update, run scan and then start a packet sniffer to see exactly what incoming requests are coming in for whatever reason
-D
Every IP on the internet is constantly getting attacked and scanned - typically automated by bots/viruses/worms. They infect machines and then use those to scan even more hosts. On my home router, I record tens of thousands attempts a day - what you're seeing is pretty normal to me.
Port 445 is SMB over TCP - so basically people trying to access shares.
Port 1433 is MS SQL - worms looking to attack Microsoft SQL servers
Port 23 is telnet - people trying to login to your router
Not sure on 2386 or 48623 but google lists them as ports people scan for stuff, so probably some service that can be easily attacked. Another common port you'll see accessed is port 22 (SSH), people trying to login to UNIX routers and certain routers. When attackers/bots/worms find ports like telnet/SSH open, they'll then try and attempt common username/passwords to try and break in.
I'd probably ignore those logs as nothing to worry about either way.
Have you tried calling up Adam yet - they may have some clues and be able to provide plenty of trouble-shooting advice :)
I have disabled port TCP 445 just to be safe - this seems to be the most common port sniffed, and the interwebz says it is hackers number 1 target.
I run a registered/active version of Malwarebytes - it goes OFF like a frog in a sock if someone tries to access my computer, so it doesn't look like anthing is getting through. I once had someone try to backtrace me through UTorrent and Malwarebytes went BALLISTIC - so I know it works.
Interestingly I rebooted my connection 15 minutes ago and sure enough it issued me a different IP from Adam - and since then I haven't been sniffed .... whereas on my last reconnection I was hammered wihtin 3 minutes of connection. Weird. I assume this is an Adam-directed DDOS, and have given Adam Internet the heads-up just in case.
But yeah I will run all the scans. thanks for the tip!
I'm addicted to the classic GTA 3 at the moment. Released a few days ago for mobile on the Android Market & Apple App Store; great classic! Awesome for killing time on the ride to work on public transport. Runs very well on the Galaxy S II. Few bugs in the first release, but pretty bloody impressive running as fast and smooth as it does on a smartphone!
Hmmm, I may have to get this for my Nexus, I love GTA 3.
I did notice a couple of reviews in the Market from Nexus users re GTA III - mass crashing apparently. Hope Rockstar sort it out!
Would be brilliant on the big Nexus display. I want one! :D
thanks mate! was on this site earlier and the port forwarding button on the left hand side doesnt come up? reckon thats why im at a loss here :(
Sometimes it is called Virtual Server instead of Port forwarding
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
    • This sounds like a perfect excuse to install a Haltech R3.
