Full Rebuild, with most receipts done 8000k's ago.
JUST ABOUT EVERY GASKET REPLACED
FUEL INJECTORS TESTED AND FLOWED
BLOCK ACID WASHED
NEW WELSH PLUGS
ARIAS 87MM FORGED PISTONS
HONED AND BORED 40 THOU OVERSIZE
MATCH PORTED MANIFOLDS
NEW DRIVE AND CV BOOTS
STAINLESS DUMP PIPES
STAINLESS FRONT PIPES
NISMO N1 TURBO'S..RATED 400HP EACH
NISMO N1 OIL PUMP
NEW CRANK ANGLE SENSOR
OS GIKEN CAM GEARS
OS GIKEN TWIN PLATE CLUTCH
LIGHTENED FLYWHEEL
HKS POD FILTERS
HKS BOOST CONTROLLER
HKS TRIGGER SYSTEM
TRUST INTERCOOLER
ARC BOV
GATES RADIATOR HOSES
GATES TIMING BELT
REMOTE OIL FILTER RELOCATOR
REMOTE OIL COOLER
HKS FULL TRIGGER SYSTEM..BOOST CONTROL
APEXI REV SPEED METER
IN DASH DVD PLAYER
IN DASH CLARION LCD PULL OUT SCREEN
12" SUB AND AMP
RELOCATED AIR CONDITIONER MODULE IN GLOVE BOX
VEILSIDE GEAR KNOB
RAZO PEDALS
BLITZ BOOST GUAGE / TURBO TIMER
PIVOT SHIFT LIGHT
ISOTTA STEERING WHEEL
SPEEDO CHROME SURROUND
RETRIMMED DOORS
GENUINE APEXI MAGS 17" X 9"..RARE AS
NISMO BOOT LIP
N1 FORNT BAR SLOTS
TRIAL SIDESKIRTS
BOMEX REAR PODS
The cam gears are still not set as I need to get it done properly so there is still heaps of power to be made in tuning.
Rego til 8th month.
pics:
http://www.carsales.com.au/pls/carsales/...rch_distance=25
[email protected]
  • 2 months later...
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
