Hi mate! welcome!
You'll hopefully get to meet most of us as time progresses, good buch of ppl here don't worry about that!
Can't beleive some of you guys get bugger all out of your tanks!
I got 492km last week! Most times I get between 410 and 430kms, and mines auto!
https://www.sau.com.au/forums/topic/109512-hi/page/2/#findComment-2021364
mine is an auto has like no mods other than a pod and turbo timer and exhaustengine wise and it chews ;)
i paid 13k 95 gtst other mods are tints kingsprings...
if ya look around youll get some nice bargins. 101 has a couple atm. there was one for 11.5k 94 gtst...
would my fuel guzzling issue be to my car running a little rich maybe? at times it smells like it is (no i dont sit infront of my exhaust and breath the fumes and im nto a ferret on meth :))
https://www.sau.com.au/forums/topic/109512-hi/page/2/#findComment-2021377
The general word seems to be to f**k my car off an buy a gtst. Some ppl have suggested going for suspension etc .... i got it with a few light mods already 18 inch g-max rims, lowered on bilstein adjustables, cat-back exhaust, pod filter front spoiler thats broken , but shit happeand it. It also "supposedly" has a chip in it. It's only got 80 000km's on the clock and we got it from my mates dad who is a mechanic (RAC) so its in pretty good nick. Not on my P's either peoples im 19, previously had a camry but i sorta blew the engine up being a dickhead. So yeah where is the cruise this sunday ?
https://www.sau.com.au/forums/topic/109512-hi/page/2/#findComment-2026188
it wasnt a silver camry that sorta hangs around balcatta innaloo area by any chance?
https://www.sau.com.au/forums/topic/109512-hi/page/2/#findComment-2026926
reverse doughies is cool
and yes u can blow a camry/corolla engine - but only the newer ones
ive seen a 1984 'rolla that was trashed
disconected tailshaft, brick on cellerator for 15 minutes and it still didnt give up
https://www.sau.com.au/forums/topic/109512-hi/page/2/#findComment-2030122
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
