Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest Boxhead
i am on 56k...
with windows xp, you can set so it reconnects if the line is dropped, and also i have my own phoneline, so i can leave internet on 24/7 unless i wanna disconnect to use house phone, if its durin day ill go use other line in the other room haha..
ohwell ...and my isp has no hour or limit resctrictions, and they leave ya on for 6 hrs at a time...
Guest Boxhead
fair enough ya gotta filter half the crap, but geneerall depending on how good your connection is.. you can usually download a movie in like 30ish hours of constant download( thats a good qual divx for 1 cd)... 30 hrs seems like a while, but if you think about it, 3 nites sleep is about that.. so just leave the pc and internet on, 3 nites, thats not downloading at all durin your awake times...
so basically yeh, 2-3 days per movie, coz if i go out, just flick open kazaa.. another couple of hrs, or if i have hockey etc, or going out for half the nite...
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
