Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest 87vlt
Originally posted by 87vlt
whoring is bad and fills the pages with "garbage" that most people don't want to read .... so please stop ... :)
sorry boxhead :D ... its the drugs the Mods have got me on ... they make me act funny and say weirder than normal things ....
The moderators of this forum are really nice people and should all be given 34 GTRs for their efforts ....
i jsut reset my ECU (Mines VX Rom)
and its stoped allmost all of my backfiring problems.
i have abotu 20% more power and heaps more torque, i know their same but u know what i mean.
the car revs up faster.
when i start the car instead of it starting and reving to 1200 then back down to 900 after 4secconds it jsut goes straight to 900 and stays there.
car seems to idle perfect with aircon.
i now have no traction in 1st what so ever. usedto get traction after a while.
now in seccond its spinning till 80. couldent do that before. (255 wide tyres)
but my clutch is slipping so i gotta baby it
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
