Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest 87vlt
Originally posted by Skyrine-Dave
87VLT
how much do you want to spend on an RB20det and 5spd?
i would like to build and RB30det, which would require me to sell my current setup....
not sure ..... can get an r32 front cut for 2200 ...... just to clear a few things up I own two VL .... both calais ... one turbo one non-turbo. The non turbo needs some work for it to be "up my standard". ie ... more power ....... I want to take the real 87vlt car off the road so I can pull it to bits and rebuild it :D
its raining here too - and strong winds :D the wind really knocks my car around i say it must be something to do with the kit - but ive had it almost feel like its picking my car up before - freaked my friend out!
Guest Boxhead
hahahah i need 2 things, special eye thingy bolts so i can fit my harness, like so i know it can be fitted whenever, and to sswap my dump pipe over for 3' one, i have the 3' and flanges, its just raining, but i cant go get bolts for harness, coz the heatsheild is off, and if i go and get the bolts, it will stop raining till engine cools down
A couple drove several miles down a country road, not saying a word.
An earlier discussion had led to an argument, and neither wanted to
concede their position.
So they sat silent and fuming for many miles.
As they passed a barnyard of mules and cops, the wife sarcastically
asked, "Relatives of yours?"
"Yep," the husband replied, "In-laws."
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
