Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
oooo uniform - what do u do? if u say cop i will ring your bloody neck haha
QLD aint always fine - got over there - started raining but it was 40 degrees in perth - shouldve stayed home for my bloody holiday haha
Originally posted by Nizmo
not too bad Erin - life hasnt been all strawberries n cream fo rme lately but u get that.
How did the job hunt go? any results?
What's up??? I haven't been reading through all the crap :D
Job hunting is still going. I turned down one today because the temp contract was less than what I've got now.
I've been extended where I am till September 30 now so that's a bonus. ATM I'm applying for a job at the Academy with the Recruits. So I'll get to work with all the young, fit and cute recruits :)
:drool:
haha becareful your folks may put u in private school (unless u already go) like they did to me to try n get me to do some work. Thing was im bright enough - got into all extra classes - just i hate homework and have a short attention span - so that didnt work n i got kicked outta school by my folks to go find a job haha
Check this out:
http://crew.tweakers.net/JvS/zooi/realhussein.swf
friend just sent it to me - friggin funny.
Guest neoGT-25
haha i used to go to a private school :D it dident work in the first place LOL they sucked!
i try doing work i just hate hw like you and i always talk in class so i get raped by the yr leval co-ordinator :) shes such a bitch... ive never heard her talk normal... shes ALWAYS angry and screaming
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
