Queensland Wasteland
paul u dont need pics of me im sure they are engraved in ur mind and visit u in your nightmares.
Well boxy ive got a pair of heels i think would just look smashing on u darling - oh n paul ive got a pair of earing for my birthday and since my ears arent pierced i though they would suit u haha mmmm maybe we could all go on a shopping spree and do lunch one day hmmm?
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
well u cant borrow my fishnets on saturday night boxy darling as my pimp will be most pissed if i dont turn up in uniform to work :D monday is my quietest night so u are welcome to borrow them then :rolleyes:
Guest Boxhead
anyway, i gotta go pack the car then leave to go to the drags, i gotta pick up 2 people on the way.. so it makes for a long trip, but ohwell atleast i get stops to get out and walk arond hehehe, cya later lauren, have ag ood day
paul - goodbye darling :rolleyes: see you tonight *makes cats noise like all gay men do*
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
