Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by neoGT-25
hahahaha, did they go "OHHHH AHHHHH"
LOL
i was the short kid (16 but i look 14) with a grey hat and dark grey t-shirt, and i walked infront of your car at one stage and looked at you and you gave me a evil look :D
Was that when I had my bonnet up?? I didn't want some faggit to walk past and turn the boost up on me and make me **** my car!! (this happened at Jamboree and some guy nearly blew his engine up cause someone thought it would be funny to turn his boost thingy up) So I death stared everyone ;)
Originally posted by Nizmo
hey Erin and Bel how u guys doing?
I'm goodles.. and yourself?? My forheads a bit sore from the helmet being a little too sore and rubbing on my forehead. It's going to come up with a bruise and look like I've had my dick chopped off or something!!
pauls its more ur attitude towards everything u have the opinion that if its ok with u must be ok with everyone else - u never stop for a second just to slighty consider the possiblities. Anyway over with now - besides u think im annoying.
haha sounds funny Erin
I was good til i was pissed off by someone but im calming down now. works ok. love life sucks. cars good - so i cant ask for much more than that ;)
work sucks to an extent, whats a love life? and the car is running like shit :D
eat more Bel lot of peopel would love ot be in that position
Yeah Erin i hate being as tall as i am but sometimes i forget that its enviable by a lot of people. guess im lucky :D I wouldnt be that vain to do that tho!!
Paul: lets not drag QLD into this too ok - anymore u have to say about the subject u can do it via PM - end of story.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
