Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
nasty thoughts about what?
Go read Erins anniversary night - hehe i dont think even u are quite this bad - although i could imagine u deciding to redo ur suspension on such an important occasion!
Originally posted by NismoGirl
Lauren, it was crap. For one, andrew didn't buy me a present (as usual, i think out of the whole 5 years I've got 2 presents!)
For two, he worked on his car all night while I was here with terrible cramping and being sick.
For three, the hospital rung and wanted me to go in for my operation on thursday but because we were out to lunch with work at the carlton crest I didn't wanna be rude and leave my phone on so I missed the call. Hence missing out on the short notice spot on thursday this week. Which sucks cause as I said Friday night I was really sick with cramps and yeah.. the usualy shit but worse.
Then he said that he doesn't care about anniversarys, they are for married people.
So i got really cut :P
There you go Paul.
But thanks for asking!
u left her at Royal Pines Resort?
hmm wasnt as bad as my mates honeymoon - her new hubby decided to bring his mates on the honeymoon and therefore instead of getting lotsa lovin she was constantly left alone while he went out - she divorced him when they got back. But i wouldnt marry a guy that when i dress nice for him he tells me to "go get changed cos u look like a whore" anyway!
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
