Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Sad pathetic little me
That was the girl I used to be
You left me on my knees
I'd trade you places anyday
I never thought you could be that wayyy
You look like me on sunday
Oh you came up with the breeeeeeeeeeeeeeeeeeezeeee
On SUNDAY Morning
Sure I haven't changed since yesterday
Without any warning
I thought i knew you
I thought I knew you
I thought I knew you Well
SOO WELL
Your trying my shoes on for a change
They look soo good
But fit so strange
There fashion So I can't complain
On SUNDAY Morning
Without any warning
SOO WELL
Oh lauren. I'm sorry :D
Hahaha.. **** my cat's funny. She runs in and jumps up and smooches me so I knwo she wants her dinner. If I don't get up she ususally gives me like 5 minutes then comes back.
Tonight I think she's really hungry. She just smooched, ran out to the kitchen, ran back and and smooched me again :|
I think she's hungry.
BBS
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
