Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Sad pathetic little me
That was the girl I used to be
You left me on my knees
I'd trade you places anyday
I never thought you could be that wayyy
You look like me on sunday
Oh you came up with the breeeeeeeeeeeeeeeeeeezeeee
On SUNDAY Morning
Sure I haven't changed since yesterday
Without any warning
I thought i knew you
I thought I knew you
I thought I knew you Well
SOO WELL
Your trying my shoes on for a change
They look soo good
But fit so strange
There fashion So I can't complain
On SUNDAY Morning
Without any warning
SOO WELL
Oh lauren. I'm sorry :D
Hahaha.. **** my cat's funny. She runs in and jumps up and smooches me so I knwo she wants her dinner. If I don't get up she ususally gives me like 5 minutes then comes back.
Tonight I think she's really hungry. She just smooched, ran out to the kitchen, ran back and and smooched me again :|
I think she's hungry.
BBS
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
