Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest pimpsta
yeah last time when I went to buy a car I got rushed in and bought the first car I could afford instead of waiting to buy an R33 (what i wanted at the time) but now i want to be different and buy a R34. Only problem is now I'm attached to my current car too and want to do a full rebuild to it ....
must admit im pretty attached to Nizmo Jnr as well and Nizmo Snr - even if it is rusting away in my driveway :P
My mum sometimes gets angry at me cos she goes "its just a piece of machinery" but for some reason me and my car have a bond!
Sometimes you have to know when to let go to though... before my R33 I owned 2 VL commodores and I swear I spend huge $$$ on the both of them.... I should have just got rid of them and bought a decent car much much earlier than when I did... That being said I have had my 33 for just over a year and don't have any regrets :P
Guest pimpsta
thats sounds way too familure
Some nights I waited up for you,
Promises you made about coming through,
Sooo much time you wasted,
That's why I have to replace you.
It makes a cat nervous the thought of settling down, especially me, I was creeping all over town. I thought my tender touch could lock you down, I knew I had you, it's got me as it sounds. The way you used to give it just before I put it down. The way you used to give it before I put it down. It's better when you angry, come in I'll pull you now.
Stop playing, you gave in,
I've gotta leave you alone
All my pride is all I have
Pride is what you had baby, girl not what you have
You're being mean to me but too bad
Be easy, don't make decisions when your mad
Now pack, you choose to run a long
I know your independant, you can make it on your own
Here with me you have a home
Well time is of the essence why spend it alot.
People make mistakes to make up, to break up, to wake up
Cold and lonely and chill now baby, you know you love me, I'm like your whole. Now instead of beefing, come home. I promise I'm not a phoney now don't bounce baby.
haha i cant :P the money from my ZX belongs to my parents as payment for the Skyline.
I spent huge $$$ on the ZX not much goes wrong with my Skyline - but i still aint rich - just spent $825 on tyres today and thank god for a credit card because for some reason my pay didnt go into my back so my savings were a little short :)
I think I have just been insulted??? :confused:
Yeah I just extended my credit card so I can put my 100,000 k service on it in the near future.... and my trip to melbourne again next week.... but I can claim that back pretty quicky...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
