Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
me too Erin - i remember the days when i first started work and didnt have a car so i used to be able to spend $180 on a jacket!! these days im lucky if i can spare $70!!
I read this thing ages ago - you know u drive an import when your car is dressed in Apexi, HKS and Trust and your dressed from the bargain rack of the local second hand store!
Paul - u want to go shopping with a female? guys usually dont like that - apparently we arent good to shop with haha. But if u want to thats fine - just save me from buying anything ok!! Im not allowed to even look. Me + depression + shops = $0 in bank account!
Guest Boxhead
no girls are horrible at shopping, this is me shopping, i know what i want, i go in, get that, and come out, this is my gf shopping, goes in, on the wya to the shop of the thing she wants, we window shop at 20 diff shops, buy things at 3 of them, have a look at another 10 or so shops on way back from shop originaly shopping at, and buy stuff at 2 of em
This year, the only piece of clothing I have bought was last monday when I bought a long denim skirt from target for $34.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
