Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
thanks Ross - i'll make sure i dont forget it now :(
hehe make ur own pipes .... is that anything like me making a new bracket for my air con compressor that was bought 4 months ago and is still sitting on my bedroom floor haha
nah its cool - he's one of the people that goes around abusing people and you never have to abuse him back because he's doing a good enough job of making himself look like a moron! Plus he works in one of the performance (rice) shops over here ..... u would think he would be a bit more open minded.
Thing is he called me stuck up and he's the one going around putting everyone down ....... anyway im with u guys now :D
Wayne are u a lil pissed by any chance? :(
actually i tell a fib - its suppose to be a joint venture between me an dmy dad.
While i was in QLD my parents had my car .... but my air con stopped worknig and it was 50 degree days over here ..... so they did the nice thing and decided to buy a new air con compressor for me ..... but gen ones are rare .... so they bought a non gen one and it needs a new mounting bracket made up for it. They say its the thought that counts :(
wayne ...... hmmm thats a bit over - only for 3 months or longer? u know if u run from the cops its only going to make things worse hun!
I tailgated a unmarked cop car for about 5km once - that was after i tried to drag it - then proceeded to do 80 in a 60 zone and the same in a 40 zone eventually they pulled me over ...... i admited what i had done wrong when they asked me - they left me go with a warning ..... easy :(
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
