Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Wayne hate to break it to u .... but its not an area the D.O.T systems have access to - they can see how many points u have left but in that department thats as far as the access goes. As for your cop lady friend - if she wants to keep her job then ur screwed besides depends on the department she's in and what exactly she has access to as well ..... not all cops have the ability to change records - and the records that are changed are well documented what was changed and by whom.
Sorry
u shoudl its heaps fun. i took this girl out ness.
and she coudlnt take it LOL she thoguth when i said i drifting i was jsut spinning the wheels a little and that im a idiot driver. took her sideways in this crucuit with a few other mates followinf drifing in tandems orta thing fairly close, then i was slideing the other way ect looks nice anyhow was perfect. she was screeming and putting her hands over her eyes. then wanted to get out of my car LOL.
some girls like it tho like liz
i got new tyres .... my last set are at the tyre place waiting for paul to pick up whe he comes back from england - theres 80% tread left on them but they have some big mofo eggs in them!
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
