Queensland Wasteland
nah see pimpspec
when u get on the highway, and u think ur top shit, then another 33 rolls along beside you, and u slow down and have a bit of a go, and u get thumped... after that its all about getting ur car faster
i probably did it to the poor bloke in the white 33 on the way back from willowbank last time, he thought he was gonna thump a stock lookin skyline too :D
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by BelGarion
nah see pimpspec
thats what my VL is for :D ........ I jsut want a nice looking skyline to cruise round in .....
well, my car is dirty again.. farken dirt roads.. and got bogged hard core too.. mud all over my car again.. haha
also, for the first time ever i got understeer in my car... just like 4wd, front wheels just slipped out... doesnt matter tho, pulled it out nicely with some oversteer. :D
nah its not that i neeed to loose weight, its that i need to be able to ride further than the top of the hill cause 1. if i get a job im gonna be on a bike, and 2. if i get fit i might look better and mabey girls will talk to me......
nah thats bein too optimistic,
ill just be tired so i can get to sleep at night or something
nah see pimpspec
then i come along in my stock 33 and flog u too.. then your worried.. haha
pimp spec ur vl is for getting beaten by r33s??
dave... is there nething u cant do in a skyline? :D
ok im on my bike, back in an hour or so, if not call the ses ill be passed out in a gutter
I don't know i haven't raced one since i started modding it. Still working on it atm, thats why its in bits. I'm aiming for mid 12s on streets ......
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
