Just changing my front shocks - dropped down the new and old to be swapped at the local mechanic. I.e I took the shock dpring assemblies out of car so car sitting here shockless..
I've been waiting for a day or 2 now and was wondering whether I should invest in a spring compressor??
Always been scared of horror stories with these. Are there any that are around $50 that are safe?
Edited by benl1981
https://www.sau.com.au/forums/topic/109585-what-spring-compressors-do-you-use/
I just went to my local Autobarn and bought whatever they had. Seem to work OK.
Only problem I've ever had is that they tend to twist along the coil - just keep an eye on them and keep them parallel as best you can.
The horror stories would come from not using them - simply undoing the top nut while the spring is under compression, parts shoot off everywhere.
i'm not a fan of the the autobarn etc ones as they twist and somtimes don't grab 100% due to the angle of the taper on some springs. and they're just awkward and take forever. for $175 most industrial tool places will sell you a big ass thing on a stand that locks the whole assembly in clamps and has a hydraulic ram that compresses the spring using a foot pump. very weapons grade and not expensive compared to what a lot of places charge for r and r of springs etc. huge convenience factor if you change springs a bit and if you share the cost with 3 mates it's peanuts.
We have a spring compressor like Scooby described in the workshop, it's a great thing when you need to swap springs many time a day. Or if you are doing Mercedes springs with tonnes of pre-load. It's an overkill for a home garage where you might do one set of springs a year. Particulary on a Skyline that has very little pre-load in comparison.
I have a pair of $25 spring compressors that I bought from SupaCheap a couple of years ago. Carefully used, they have done over 10 sets of Skyline springs without a problem. I just make sure I keep myself out of the firing line.
;) cheers :)
Edited by Sydneykid
Hey guys - thanks.
I just borrowed some from my local mechanic - so heopefully won't injure myself!!
A mate of mine had a set of super cheap spring compressors braeak on him...not a pretty sight. As a general rule, I avoid placing my life in the hands of anything Chinese.
The bottom is free now - I can twist it, however the top seems to still be under a bit of tension. I guess cause I didn't grasp it close enough to the top.
Will this give a bit of impact as I loosen off the remainder of the top bolt..or make it harder to put the compressed spring on the new shock??
http://img93.imageshack.us/my.php?image=img00334iy.jpg
Edited by benl1981
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
