In my quest for subtle mods and to keep the defect man away I have stumbled across this side mount intercooler (SMIC) as a stock replacement. I have now fitted it and my boost has risen from 7psi to 8.5psi so it definatley flows better, its cooling ability is yet to be tested. It certainly looks impressive for a SMIC, must be that 100mm thick core! ;)
Here is a couple of pics comparing the different SMIC for the R33 GTST. The Stock R33 SMIC, Stock R34 SMIC and the Aftermarket R34 SMIC.
Notice the size of the air galleries, not at many as the Stock R34 SMIC but considerable larger. Maybe it will flow better, but not cool as well?? Time will tell.
https://www.sau.com.au/forums/topic/109591-now-that-is-a-smic/
If you want to avoid the FMIC then what about a water to air setup, like the PWR barrel cores?
After picking up a PWR radiator for the GTR I spoke to them about those barrel cores. . . . . Not really a feasable option, purely on the room aspect. . . . No way you could fit them to most newer road cars, especially the GTR.
Anyway, I just want to stick with the SMIC for as long as possible. I just get annoyed when people run out and get a big FMIC for there nearly stock cars. I am going to hold out for as long as possible. I am interested to see how it goes in the coming months at Willowbank and QR. . . :) Should be fun :P
I have a shroud which I had to modify a little to get it to fit but should make it work a whole lot more efficiently forcing all the air through it.
Out of interest, how does well does it fit in the front left guard area.. have you removed the panel that's in front of the wheel?
How much are they as well..
Wouldn't mind getting a R34 gt-t SMIC.. as really i don't need a huge one.. but would be nice to have..
It actually fits a little better than the Stock 34 one as it is about 10mm shorter so it isn't as much of a stretch to re-fit the inner guard. But it all bolts up exactly the same as the stock one, apart from the shroud you wouldn't even know its there ;). This has only given me an extra .5psi, if that, over the stock 34 cooler, so they are pretty good. I am assuming though that this should flow a few more KW once I start getting up there, but I am only aiming for 180ish rwkws atm. Thats heaps for what I want to do . . . . . Bring on QR!!!
I thought is may be a TRUST one, but the other TRUST one I have seen had TRUST stamped onto the top of it, and the ARC ones have that metal badge stuck on the top. . . . not sure what it is. It has a Nismo sticker on it but I have never heard of Nismo making these????
BTW, I will have a Stock 34 for sale now. . . . This
The only thing I am going to do it get a peice of aluminium and extend the front of the shroud right to the lip so it doesn't break catching too much air at high speed and flexing down too much.
Here is a pic showing the inner guard fitted (who would know. . . hehe) -
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
