HOW MUCH STORAGE DO YOU HAVE?
61 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
this machine work has a 40g drive in it. Hard core, and onboard gfx and all :lol:
home media machine has a 300g and an 80g
home games machine has one 80g
hard drive is the thing on the back end of the computer with taht big fan in it Dasblitz
  • Replies 67
LoL..
I made this thread to get an idea of what the average Joe has for storage.
My range of PC's come out with 160 ~ 200GB hard drives at the moment and that seems the accepatble storage size for most new PC's.
However having said that 250GB drives are getting extreemly cheap now, probably due to the new wave of 600 + GB Hard drives hitting the market soon.
Sizes have been pushed higher and higher due to the Digital Video Storage requirments of HD TV and SD Digital TV recording.
For example My Media Center Records HD TV at around ~3GB per 30minuets.
Its a killer!
:laugh:
600gb in my pc 250gb in my portable, 80gb in my laptop for perth side.
At home in Singapore 4 pcs 200gb, 160, 120, 120. 2 laptops 40 and 60gb shared among my family.
Total of ... ermm... *math*... 1630.
Just got my pc so the 600 came with it. =)
Alpha, i heard that using SLI for graphic cards are at only about 80% efficiency ? So that means u get about 1.6x performance gain? Currently using a ASUS p5n32 SLI with the nforce4 chipset.Got an Asus 7900GT top edition in it. Thinkin of gettin another for the SLI but was thinking if it was more worth it to change the 7900GTX instead.
Honestly.. Id push the 7900GT that you have and wait untill the next wave of SLI cards.. I have a feeling we are about to see a leap in vga technology.. * Vista will be pushing that leap..
Sounds like a good plan :D Thanks !
  • 1 month later...
3x 80 gig SATA drives in a raid 0 array
120meg/s goodness ;)
EDIT: Forgot I have a 40gb 2.5 inch in a USB 2 caddy, good for sharing movies and whatnot with mates
Also got a dual core opteron running @ 2.2Ghz and a 6600 GT.
Don't have any jobs going do you alpha? I make for cheap labour :whistling:
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
