Hi all
I have a 34 GTT and was wondering when the radiator fan (the one that blows onto the radiator) is supposed to be on?
Is it supposed to be always on?
In the morning I drive it to work (5 mins away) and never see it come on, is this strange?
My oil and water temps all seem normal.
Thanks
https://www.sau.com.au/forums/topic/109808-radiator-fan/
Theres the black fan on the right side of the engine bay, and then there is the big white fan that blows onto the motor.
I am talking about the smaller black fan thats pushes air through the radiator. Dont know whether this is the aircon fan? So many fans I am confused! haha
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2023158
Had you done a search, you would have found .....
I have done a search and found 30 pages of crap.
And on some threads, people are saying it comes on when the car is on, others when the temp reaches X degrees.
I found your post as per below:
"The A/C fan is controlled by the thermatic switch in the bottom tank of the radiator. It only activates when the coolant temp gets too high. Under normal circumstances, the standard engine fan is able to maintain sufficient airflow to keep the A/C radiator cool.
However, if you have the A/C re-gassed with the modern stuff (R134a ?), get the fan re-wired to come on with the A/C."
Is the A/C fan the one that blows onto the radiator? If so then mine does not turn on when the air con turned on during a cold start (I hear something else click and sound like a fan though when the A/C is on, I think thats the compressor)
How hot does everything have to get before its turned on, even short 10 minute drives and it doesnt come on. I should really take it for a thrash and find out.
Edited by nuffsaid
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2023196
It only activates when the coolant temp gets too high....
ie, when the engine starts to overheat with the A/C on. The 'switch-on' point of the switch is a few degrees above the thermostatted temp of the engine.
As I said in the post of mine that you found, the standard engine fan is usually capable of pulling enough air through the A/C radiator to control its temperature.
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2023264
Oh so even if the water temp guage is sitting halfway, it doesnt mean it should come on?
But say the air conditioning is on, and its a warm day and the car has been driven around for a bit, you'd expect it to be on right?
And when you are referring to the engine fan? thats the big one in the middle right? then where is this a/c radiator?
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2023278
Right.
Not necessarily. If the engine isn't overheating under the load of running the A/C in the hot weather, then the fan won't come on.
Yes, the one attached to the front of the engine.
It's the silvery one, out front; the one with the A/C fan bolted to it.
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2024515
Most of the points above I understand.
However, now I have to clarify:
are there 2 fans only, the engine and the A/C?
so the one I am referring to must be the A/C fan?
then why is this fan blowing directly onto a black radiator (the main big one) and not the A/C radiator which I now have to go and find somewhere. hahah
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2024557
Maybe someone painted it. If your A/C works, then you have an A/C radiator in front of the main radiator.
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2026464
A/C definately works, especially when the car is parked under shade on a hot day.
However if the car has been out in the sun all day on a hot day, it doesnt work as well, but thats normal I think, all this black interior in the car doesnt help on sunny days! hahah
I also noticed that even at night, the cabin of the car can get a little warm, is this normal for skylines? they seem to make alot of heat. you can feel warm air coming through the air vents sometimes (heater is not on)
https://www.sau.com.au/forums/topic/109808-radiator-fan/#findComment-2026499
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
