  • Replies 46
Originally posted by int21h
Nice work Rev.
How much did that set you back?
If you don't mind me asking, who or whats Nengun ;)
Nengun is someone that used to live in Perth but moved to japan. He has a little business selling aftermarket parts over there.... I recently bought my FMIC and AVC-R from him. He ships the parts pretty quickly and you can potentially save alot of money buying through someone like himself as opposed to buying the parts locally.
gts-vspec,
Might have a look at doing it myself. I've changed timing chains and things before, it's even easier when its a belt.
The key is to mark everything set at 0deg TDC and line it all back up.
The only thing I have never encountered is the crank angle sensor thingo. Anyone had a go t doing this themselves?
Who has had problems with installing the cam gear?
What do the tuners stuff up? Is it the timing position or do they damage parts upon install?
I'm just curious to know GTS-Vspec as it sounds like you have had some experience around this issue.
Cool, wish i'd known that earlier ;)
I just bought a HKS Type 1 turbo timer from PerfectRun. I'm starting to wonder if it would of worked out cheaper buying it locally.
Freight was the big killer at $40!! and it's been 3 weeks since i first ordered it.
I don't think there is anything particularly difficult or tricky, but some places are lazy and get apprentices to do this stuff, they tend to leave things loose or don't get the timing belt right, so it can be messy after that.
See'ya:burnout:
Rev if you have Issue No. 23 of High Performance Imports they go through installing Cam gears in the technical section.
The major point they make is :
"Be very careful; after each and every adjustment, turn the engine over by hand to ensure there is no interference between the pistons and valves. This can quickly make the whole task very expensive."
It also says to make sure the inner adjustment ring is set to zero.
And also to make sure that the bolts are nice and tight, so the gears dont slip position and make the engine stop.
Hope those little snippets of info helps ;)
If I feel game enough I'll put the gear in at home, and sadly dissapoint those guys waiting to see the dyno of my car.
Then again I might just let someone else get the cuts and scrapes and pay them to do it. In that case I will get the dyno time.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
