Max Power about your XR6t I unfortunately work at Adrian Brien Ford, I have seen this happen alot. We had a staff member whos bought a turbo for her husband, it had some clutch problems they wouldn't do it under warranty - this caused a lot of problems around the place as the are so F***ing lazy when it comes to warranty work.(sorry you can probibly tell that I absolutely hate my job and work but this is the truth about warranty work in dealerships they make more money out of the customer than they do Ford)
I hope my warranty works as i had to come home from the cruise early as my clutch is playing up!
Edited by Whiplash
I hate to say it whiplash but the clutch want come under warranty because it is classed as wear and tear I think. I had to replace mine myself $4500 later. :D
wot u put in it a OS geinkin (spelling :S)
and did u do the work your self
i just got Kent brake and clutch to do mine and cost 800or 900 i cant remeber of the top of my head i think 900 for the GTS-4 with a HD xtreme clutch
BOUGHT MY CAR FROM rEDLINE AND I CANT SAY I HAVE HAD ANY PRBS WITH IT.... u DO PAY A LITTLE EXTRA FROM THEM BUT AT ELAST YOU KNOW YOUR GETTING A HALF DECENT CAR (MINE HAD THE AUCTION PAPERS AND STUFF COME ALONG WITH IT.... hAVNT HAD ANY PROBS AT ALL AND WHEN I GOT RAA CHECK THEY FIXED THE STUFF THAT WAS WRONG APART FROM MY REAR SPOILER LIGHT BECAUSE Icbf.
i went into redline a few weeks ago, looking around for my first skyline...however, i've been lurking round for a while checking out prices, and yeah they did seem a little expensive, 2-3k more than other places.
also, you'll be kinda hard pressed to find a GT-R there. the only one i saw was an R32. a lot of 32 and 33 GTS-T's, and most of these were pretty clean.
they're pretty good if you want a supra or 180sx as well, and one thing that i did notice that the brakes on a lot of the cars were very rusty, so that's something you probably should take into consideration when you look to buy...brakes aren't cheap.
new brake pads allways go rusty when i got new pads in my car i would get up and over night there was a rust like residue over my rotors
i dont think that is too much to worry about
A good option is interstate purchases, with RTA inspections and such .. They pick up pretty much everything and more in the way of faults. I saved myself quite a few thousand just by going interstate and driving it back (after taping up the front to prevent stone chips). I could've got it transported but how better to check a car for driving faults than driving it back from Sydney?
I went through http://www.japimports.com.au/ and found Brad Host to be a good, honest dealer. Couldnt be happier with my purchase, he even drove it to the airport for me to pick it up :happy:
They sell aftermarket warranties too for a reasonable price, not that I have had a need but I have called the firm querying. They cover almost everything, clutch, diffs, even exhaust :P
Maybe not relavent to the topic, but a possible other option :(
Interesting option, but do different states have different rules regarding compliance and what is and isn't legal?
For example, if I bought a car that was complied in VIC could it be possible that it is infact illegal in SA due to different laws? I am new to all these rules and regulations so please correct me if I am wrong..
Cheers for the link though!
^^^ yes that is spot on the money my opinion if u dont want to go over the pits @ regency is buy local
but it is a very good option too if u dont mind a visit to regency least it doesnt need full compliance i believe
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
