pplz i brought a power fc off a memeber on here just finished rebuilding my motor went to start it today and the power fc wont start the car when i turn it on and the fuel pump wont stop running and all the lights on the dash flicker
so i grabbed a standard ecu and it starts can somone out there help me asap as im in need of this car so i can go away
https://www.sau.com.au/forums/topic/110114-power-fc-wont-start-the-car/
yes series 1 and series rb25 use the same model powerfc.
the only suggestion i can offer is to
check the powerfc is connected properly (loom plug is in OK)
no bare wires on the loom are shorted out
no wires loose or not connected properly
the powerfc doesnt have a burnt smell to it
does the hand controller come up and run ok if you just turn to ON and don't start the car? like can u actually use the hand controller like this?
umm no boost kit that i know about but how do i turn it off also no burnt smell the screen flashes with the sound of the clicking of the car its lights up i might try the power fc on a mates car
how do i turn the boost kit off i dont think i have one ???
try it witha jumper battery connected, noticed mine turns off and will not start the car without heaps of power..
plus it always turns on the dash lights then switches them off, clicks then they come on and car starts..
i cant get into the menu the screen flashes on the hand controller the relay in the back on the car in the boot next to all the fuses clicks as well while trying to start
i pmd the guy who sold it to me no reply yet
it was brand new im just hoping i can fix it the car has being off the road for 5 months now icthing to get it going
if i put up the numbers of the ecu can someone tell me wat model it is for ??????????
on the side of the ecu it should have the the model number
your looking for ECR33 or RB25 something something which should confirm the model number. its on a white sticker
when mine was fried the screen would go crazy and make constant ticking noises and never boot up
well the way i figue it can be the relay cause the stock ecu starts it no props im goin to try the power fc on my mates car today and ill post some numbers up if i cant get any futher with it
johnny cash : slept like a log just finshed work at doms
hey, mine did the exact same thing when we had the AFM wired up wrong. All the dash lights flicker on and off, the fuel pump goes flat out, and then eventually the fuse blows and the dash stops flickering.
Scared the shit out of us. No damage to the powerfc, just a blown fuse.
If its not the AFM, it will be something else shorting the f**ker out.
Good luck mate, and be careful.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
