Hey all just a quik question What should i be looking at for my next mod i've got:
Small pod filter Restricted due to space from modified intake pieping
3" Dump pipe into Stock cat into 3" catback exhaust system <~~ 2 mufflers
garret T04E turbo .60A/R compresser dunno exhaust but full boost by 5000RPM
HKS exhaust manifold low mount
HKS external wastegate
bleed type boost controller
Made 227HP@14PSI at wheels im looking for 300HP and some more mid range pull.
dyno graph in attachments.
so far ive thaught of changeing the intake to run a full size pod filter and getting a 3" high flow cat and removing 1 muffler to increase flow. ive since turnd down boost to 12 cause the guy from the dyno said it was leaning out a bit at top end no detonation YET afr's get too 14:1 at top end on 14psi (yaay go stock computer and fuel system!!) any other suggestions?
money has run dry atm but just wanna plan ahead save spending money on things i dont need.
https://www.sau.com.au/forums/topic/110139-whats-next/
Im not sure how ur standard ecu is running the car... but before you do ANYTHING go get an ECU and get it tuned! Even if its with standard injectors/afm/fuel system blah blah as slapping a big turbo on and raising boost without any form of tune is just asking to blow the motor!
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2031021
yea woops i forgot im runnin a 600x300x76 hybrid FMIC and remacarbly the car is smoth to drive you just have to wait for the power. but yea i think after i get rid of the intake and exhaust restrictions ill get that computer it needs and a electronic boost controller cause as you can see on the dyno chart it really dosnt know what its doing with the fuel. thanks for the input guys!
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2031057
yeh like wat everyone else said...
i cant believe you didnt at least upgrade your fuel pump and get an fmic...
i wouldnt even dream of putting a bigger turbo without those.
or maybe you just forgot to add it to your list of mods coz they are such obvious things to do :)
Edited by joh21m
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2031058
im stunned that its no pinging at 14:1 AFR up top end ..
usually can run 14:1 down low before boost kicks in, but then it should be 11.5 to 12:1 ..
first thing if ECU is out of the quetion, rising rate FPR 2:1 rating, to get the injectors flowing that little bit more.. just to get that AFR a bit better....
like $200 and will be alot safer than what your doing now.
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2031101
woh i really didnt think that it was that bad but yea since the guy at the dyno told me i droped the boost to 12 psi and was talking to some people and they mentioned and apexi safc or something i think its just a chip but do you reckon that would at least fix up the fuel a bit combined with an upgraded fuel pressuer regulator and where do you think i should look to maby pick up a second hand one??
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2033909
if you keep running it like that without a tune, you're gonna blow an engine.
your afr's are all over the place, you are running dangerously lean at the top end of the graph where it peaks at 14:1, i'm suprised you haven't done some serious damage... I guess this is what an afr graph looks like when you slap on a turbo kit, boost controller and just go for glory!
I would also argue your turbo is very laggy, the car musn't feel very drivable, you could consider changing turbo's, a tune will improve your low end response, so will cams but only to a certain extent.
as far as mods go (apart from a remap or aftermarket ecu - don't get an SAFC, stock remap is better if you wanna do it on the cheap)
i wouldn't worry about z32 afm or electronic boost controller, your tuner will be able to tell if it's spiking or your current afm is maxing out, and the manual boost controllers some dude is selling here (there is a big topic about it somewhere on the forum, search) are great.
- Fuel pump & injectors
- high flow cat + air filter
- cams
- head work (porting etc.)
- bottom end (pistons, rods etc.)
and also have a think about how long you're gonna keep the rb20det for, and if it might be worthwhile sticking an rb25det in it. Also consider "safety" mods such as oil cooler, aftermarket radiator
Edited by MerlinTheHapyPig
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2034210
after reading this thread im freaking out now :) I have a r32gtst with a HKSGT2540 and apexi FMIC , i have no idea if the ECU has been remapped or is stock. I got the car from japan and have no info on this. It has a manual boot controller and it is set at 14psi , thats the way it came. I surpose i should get it on a dyno to know.
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2035330
Undertoe, its always a good idea to get the car on the dyno for a power run at least every 6months to a year to check afr's IF its running a nice turbo.
Fuel pumps/injectors can and do get tired/clagged.
Back to the origional question.......
This would be the plan of action if it was mine...
1. Fuel pump
2. Cat converter sorted
3. Fuel pressure reg
4. Adj. cam gears to help spool
5. PowerFC (Possibly including the pfc boost control kit if the current setup has issues holding boost)
6. Tune it and wind the boost up until she doesn't make anymore power or if injectors are limited which should be with a bit of fuel pressure some where around 200-220.
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2035578
1. Fuel pump
Thanks mate , im going to get a whole new exhaust system , should i go 3.5 inch or is 3in fine with this size turbo. Also by sorting out the cat do you mean a highflow unit?
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2035645
Thanks for the info guys yea where on the northside of brizzy would be a good place to get the ecu re-programed and what is the normal cost for this?
I have thought of doing the rb25 conversion and now that i look at it i probly shoulda done it instead of putting this turbo on but all aside whats done is done and now i dont have the money to do it so ill try fix what i started so do u think if I can get it retuned with a fuel pressuer reg. it would at least be safe and then ill start saveing for that ecu!
Once again thanks for the heads up and hopfully i havnt dammaged anything!
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2036708
DR Drift (son of rajab of re-tuning stock ecu's) is making a trip up to Nerang in the very near future.. Check the QLD section.
Rising rate regulator and a big in tank pump... Plus the cat and inake and you should be set for some decent figures, with the re-tune of course.
If your smart you could have all this done for a little over $1000
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2037625
how about a FMIC!!!!!
if you dont have one get one now.
Then go with Fuel pump, injectors and a ECU, and you will be laughing
Yep, good point. You'll start maxing your injectors and fuel pump soon. So get all that out of the way.
https://www.sau.com.au/forums/topic/110139-whats-next/#findComment-2038522
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
