NP mate. it does not require welding but it will require your machineist to machine down the crank and fit it correctly. its not a easy job and you have to have the crank out of the engine to do the task.
what was the other question? did you read through this thread ? it has everything you need.
always balance everything that goes up and down and round and round. Might as clean up the crank too while there, any dags and casting marks clean it up and get it slippery smooth.
In regards to the RB25 , why is the front feed blocked off and the rear feed restricted but with the other engines its the rear feed that gets blocked off and the front feed get's the restrictor as per sydneykids table ??
we dont know where sydney kid comes up with his ideas but they have been proven to work time after time after time so its a good idea not to ask questions how he comes up with it...
I think it may be because the rb25 has hydro lifters and its required to have it setup that way to run them properly where the gtr has solids which does not need the same kind of oil configuration.
Mine is done as per Sydney kids instructions and its been running for 2 years and 363rwkw.
There are many others whos are running well too. I dont know why people have to question it all the time.
well i certainly do not know thats why i am asking these question's b4 i put the motor together .. i want to be 100% sure all is correct ..
in saying that guilt-toy if you install the non vct 25 head you block of the rear and feed the front but with the 25 vct head its opposite and both have hydraulic lifters..
thats is correct??
I run the non-vct RB25 head.
I blocked off the rear restrictor as the Rb26's are and run a 1.5mm restrictor up font.
Works fine no ticks, pops etc. Went from shit loads of oil everywhere over 5500rpm+ to a bone dry catch can. Still plenty of oil floating around in the cam covers. Prior on idle oil was puddled up to the base of the cam so you couldn't see the lifter. Now u can.
As a few have experienced; if you experience hydraulic lifter tick once the motor is warm its a tell tale sign the motors on its last legs. Recently happened to a mate of mine running an rb30det.
what went on your mates engine when it went ? i get lifter tick for about 5 seconds when i start the engine on cold startup only...
just wondering what went on your mates engine
Lifter tick when the oil was warm and poor oil pressure no bottom end knocks or noises. The lifters were silent when cold.
Mine is fairly decent on cold start up, I only get an occasional tick. I can't remember the last time it ticked but I haven't been driving the car during the week for a while.
The RB20 was the same. Occasional tick.
Yeah well i checked my oil change sticker and it has been 6000km's since a oil change!! so thats why they would be ticking.. oil is getting a little old but its 300v chrono which is known to last longer then normal fully synthetic oil.
will change it in the next week or 2 :) ooooopppss
thats a pretty over the top solution Beyond Horizon, you will never fit the standard piping back on if you go a fitting like that. A simple 90o angle with 1/2 hose barbs on one side and 3/8 BSP thread on the other can be tapped into the head just to the right of the fitting in that pic - much easier, smaller and about $3 for the fitting
But will it flow as well, bearing in mind we are talking gravity feed here?
Do you know where i can find some pictures of this modification you're talking about or do you have some ?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
