hi im new to my skyline
what does this stock boost gauge mean?
doesnt +7 supposed to be 14psi?
mine only goes over the "0" just a tiny bit even though i did that mod where you can undo and leave your car running 2nd stage stock boost all the time
so is mine supposed to be like that on the stock boost gauge or is there something wrong?
https://www.sau.com.au/forums/topic/110844-stock-boost-gauge/
start with checking the hose to the boost guage.. it is located in the drivers side rear of the engine bay, right in the corner. hose comes from the back of the plenum.
if thats ok, check all the hose clamps on the intercooler piping.
try to test with an aftermarket guage.
ummm something seems to be wrong. 7psi should be in the middle (which is what you should be running if you've bridged the solenoid to leave it permanently high boost) of 0 and 7mmHg.
You're right, 7mmHg = 14psi. Boost leak somewhere??
0 is "atmospheric" pressure. -7 is vacuum , +7 is boost. And I'm sure there are posts around suggesting that the scale on the gauge is "x 100mm Hg", so the range is from -700mm Hg - 700mm Hg (760 is 1 bar or 14.7 psi)
ALL engines cruise under vacuum, so your car should always have the boost gauge sitting between -7 & 0 under normal driving conditions. Only when you hit boost should the gauge indicate a reading > 0.
Now back to the original problem - if the car feels like boost is working, then it is obviously a leak between the manifold and the gauge. If it feels like boost is not happening, but you can here the turbo working, then it is a problem with the plumbing between the turbo and the inlet manifold (slipped connection usually). If it feels like boost is not happening and you can't hear the turbo, then it's likely a dead turbo (probably blown exhaust wheel).
I've always wondered, is it best to cruise with more vacuum (closer to -7) then it is to cruise closer to 0... Will more fuel be consumed under less vacuum?
Just been wondering that for a while... anyone?
fuel consumption is based on the stock ecu using its factory closed loop feedback. it doesnt have anything to do (that i know of) with boost pressure. as the fuel injection values off the maps are based on engine RPM and airflow meter load, not boost pressure.
Wouldnt more vacuum mean theres greater flow past the Air flow meter?
I dont have a clue when it comes to this, just making wild guesses :laugh:
The vacuum is behind the throttle plate. The air flowing in past the throttle plate to "fill" the vacuum is controlled by the position of the throttle plate. At a high vacuum - closer to -7 - less air can flow past the throttle plate (small throttle opening), so less air is flowing through the AFM.
Less vacuum actually equates to more AFM airflow due to the wider opening of the throttle plate.
You can only cruise at a given vacuum given the condition of the engine - to vary the vacuum, you need to change the throttle plate position, so you change speed, so you aren't "on cruise".
If you study the maps in any programmable ECU (PFC, etc) you will notice that the injector times at low loads (high vacuum) are much shorter than those at higher loads (less vacuum, or boost).
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
