  • Replies 66
Popular Days
Yeah - the couple of singles Rogue Traders have had are OK. That video with her at the school or whatever was pretty good. Why doesn't Delta make a video like that?
BTW: Phillapousis - top work big guy :P
https://www.sau.com.au/forums/topic/111184-music/page/2/#findComment-2049286
Looking at current Australian music - Delta should be in porn. I'd buy more of her DVDs that way.
Thats un-Australian...and since she is my friends neighbhour..and its possible we swam in the same pool as 6yr olds then i resent that statement...when she busts up with that pommie git i am going to hit her up...we have history god dammit
https://www.sau.com.au/forums/topic/111184-music/page/2/#findComment-2049288
yeah the crue concert fans were cracking me up.... fcukin everybody who walked outta there was covered in tatts and looked generally scary
i was sitting there and the esplanade hotel with this hot little brazilian chick and all of a suddern like a wave they were everywhere... from the convo's i was having with a couple of them the concert was going off
https://www.sau.com.au/forums/topic/111184-music/page/2/#findComment-2049289
I wish Hollywood had identified my driving potential..i could have been the next Cole Trickle...but instead im just a hack that cant even say i got one away on Nicole..
Work, well i kicked a goal last week, so they can puy up with my druken sad ass...a bottle fo scoth is a good effort for Sundie night
https://www.sau.com.au/forums/topic/111184-music/page/2/#findComment-2049329
God damn I hate the f*cking Streets,
Keep singing the Days of Thunder song and pining for lost loves instead.
Cary Elwes is too pretty looking to be a NASCAR driver.
I think Cole Trickle has secret dreams about him in the change room.
https://www.sau.com.au/forums/topic/111184-music/page/2/#findComment-2049347
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
