  • 3 weeks later...
I got a new PB last night. Was really fun but cold tarmac made launching tricky.
I tried a couple of times to go for reaction time and could hit 0.1s ok. Best was -0.06 - Yes, Redlight but hey 6 hundreths.
  • 8 months later...
As a benchmark, the hi octane r32 GTR ran a 9.7 qtr mile with only 440kw and the car is setup for circuit (not a drag setup).
I also ran an 11.1 with only 325kw :)
I crossed the line in 3rd gear and hit the limiter so that setup capable of a high 10!
I did logging of ecu and found split cooler pipe, it was only making 16psi on last run but my guess is that is was leaking for a while and not hitting full boost but I can see the split now
Prob is I'm going to have to go hard pipe kit but I like the stock look
  • 1 month later...
R33 GTR
ran a 11.4@ 132mph (WSID)
Was my very first time racing the car and to make matters difficult the car was in 2wd (attessa 4wd pumps were not working and not allowing the 4wd to be operational).
Have since got the 4wd system working again, will be going back soon and hoping to better it
Edited by dave88
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
