Hey all,
after tuning the boost controller im now chasing more power and revability.....
Im looking at the just jap 3" mild steel dump pipe, i already have a catback (something like 4inch ha), pod, boosted it etc, just dump pipe and maybe cat later down the track
The dump pipe is only $195 and is it a good one? wat else is on the market for that money?
And can anyone estimate the power increase? the jj boys said it would increase midrange from freeing everything up.... skylineaus opinion please..
thanks
ed
https://www.sau.com.au/forums/topic/111409-dump-pipe-rough-estimate-please/
damn theres some big increases to be made from the split pope BATMBL is selling... its double the price though..... hmmmmm i wonder wat the kw difference is between that and the jj one.....
greddy make split dumps they look very good, you can see the split from the outside though i dont know how long they are but its just the normal dump pipe size maybe 30cms if lucky but it must work they use them on all there cars!!
Have fitted two split dumps supplied by the BATMBL this week, one also with a high flow 3" cat upgrade, defenetaly made noticable difference to both cars, highly recommended. Just remember you get what you pay for.
Hey all,
thanks
ed
i have already fitted a split dump from just jap, I have found a little more thottle response. check the ACT thread nightmare install!! for some photos of the job, I also heat repped the hole dump (not in photo yet)
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
