  • 3 weeks later...
  • Replies 224
im interested in the little plastic piece for the horn that is behind the steering wheel. im talking about the ring with the flat cable attached. mine is broken and these are pretty hard to find here in the US.
thanks
clay
have no radiator, front quarters or exhaust. all other parts must go this month. I still have engine, gear box and complete interior/exterior in top condition. the car is black
make me some offers!
pics can be sent on serious request when I have time. cheers
Looking for YOKE to go into R33 GTS 25t gearbox.
Will take whole tailshaft if necessary, but only need front section.
Email me on [email protected]
Thanks,
Dennis :ghost:
  • 4 months later...
Man looking for the driver's side window panel, i'm been broken into.
How much for it, i can cover COD.
The window panel is sold - these are the parts I have left guys....
REAR BRAKE SET
STARTER MOTOR
MASTER CYLINDER/BRAKE BOOSTER
IGNITOR MODULE
ECU
CASTOR RODS (PAIR)
FRONT LEFT LOWER CONTROL ARM
AIR CON CONDENSOR
HVAC FAN BLOWER
HVAC UNIT (HEATER CORE, NO LEAKS)
PEDAL SET
PETROL TANK
GLOVE BOX
DASH PAD
CENTRE CONSOLE WITH LID
R + L DOOR TRIM (NO DRIVER SWITCHES)
R DOOR
R MIRROR
STEERING COLUMN COVER
BOOT RELEASE CABLE
BONNET RELEASE
FUEL PUMP
OUTER PILLAR TRIM
FRONT HUBS
PRESSURE PLATE
ENGINE WIRING
WIRING LOOM
POWER STEERING RACK
STEERING COLUMN
REAR ‘SKYLINE’ SIGN
TOW HOOK
ALL SEATS
R REAR QTR PANEL
L REAR QTR WINDOW
CARPET
FRONT WIPER MOTOR
REAR WINDOW
SIDE INDICATORS
SPOILER
DIFF
INTERIOR LIGHTS
INTERIOR PANELS
OTHER SMALLER BITS AND PIECES
My no. is 0401 598 511
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
