hey all,
Begining to tire of my 94gtst's continues problems and I am considering selling it. My mate has a 98 model wrx which is pretty standard apart from a brass button clutch, full exhaust and stereo. Just a few minor things like aftermarket suspension, 18 inch simmons blah blah.
The question I have is how do they compare to a r33 skyline? Ive been in it and to be honest it seems quicker than my car. How reliable are they engine wise? Iknow that the gearboxes etc are not that strong.
Blown a motor in my 94, replaced that. Lost my lic in it a while back. Now im having electrical problems.
Any thoughts?
Anyone jumped the fence and can comment from a owners point of veiw?
thanks
https://www.sau.com.au/forums/topic/111570-thinking-of-getting-a-different-car/
you lose your licence in your 33 but you want a faster car ? that will fix the problem hahaha. My brother had that problem with his v8 commodore and he now drives a 83 corolla. Problem solved.
Edited by fEkuaR
That was a fair while ago that I lost my lic.
The car has a front mount, pod, cat-back 3.25 inch exhaust, exedy brass button clutch, suspension work.
It is just not generating any power above 5000rpm. Got a sloppy idle.
I just had an exhaust leak fixed and it runs a bit better but. Its starting to piss me off.
My mates rex is starting to look tempting unless i can fix this f**king thing.
My wife has an 05 WRX (stock) and I have a series 1 R33 with the following mods:
3" turbo back zaust
FMIC
Unifilter POD
turbotech boost controller
PFC
High-flow R34 turbo @ ~ 1bar
The 33 is soooooo much more fun to drive than the WRX and since the PFC was installed and tuned it feels a shitload quicker than the rex as well.
IMHO, stick with the skyline and get the issues sorted. Once you have it running well and add a few select mods, you will be much happier than with a WRX.
Before you had the pfc, did it still feel quicker?
Me and him had a little bit of a highway entrance tussle when i had my old motor. I only had the pod, and 3.25 inch catback exhaust then. He completely smashed me with his stock 98 wrx. Im guessing part of the reason is because he hasnt got a speed cut, so im guessing a fuel cut is absent aswell. Have to admit Ive never liked my car that much since then.
So maybye a better question to ask you guys is,
Give me an example of how you dominated over a rex in your 33 gtst?
Might help me learn to love my car again! lol
Yes, but not to the extent it does now. I had an SAFC2 before the powerFC and it was really flat all the way to 5000rpm but then went like a rocket from there to redline.
Now it pulls like a 14 year old schoolboy all the way through the rev range.
hahahh. oh ok.
Hey i just got done replacing spark plugs.
Im fairly sure they are the wrong ones unless the computer needs to adjust to them, im not sure.
They are bosch fr8dcx with a 1.1 gap. Are they the wrong ones? the guy who i bought them off looked in the book. Unless he has given me gtr ones?
Car is detonating if i even try to put the boot in now.
hahahh. oh ok.
I wouldn’t waste my time with a wrx I went thru the same thing of wanting one, but my car was in tip top condition. I had 230rwkw and never ever seen a wrx in front of me. Had fmic, exhaust, pod, 13psi stock ECU ect..
Get your car to a performance / mechanics shop mate and let them have a look at it (Get some advise where to go who knows there stuff). Don’t bother with bosh plugs... go with NGK Iridium (BKR5EIX-11 correct me if I’m wrong) plug and gap them to 0.8mm. Your car may have all sorts of problems because it sounds like your not really mechanically minded (no offence). There could be an easy fix problem but we can guess all day so take it in somewhere mate and get her checked out.
Cheers,
Alex.
230kw with the stock ecu..... howd you do that ?
Cheers,
Alex.
hahahh. oh ok.
get the plugs out of there. go and buy some NGK BCPR6ES or BCPR6ES-11 and gap them to 0.8mm bung them in and then check the base timing.
The poor idle is most probably related to the base timing, My guess is the bolts on the CAS are probably loose, and has let the timing slip.
Once the timing is set go place a mark on the CAS and the front timing cover for refference in the future.
You have a FMIC and no way of adjusting the fuel and ignition map?
I don't know who gives you such crap advice on what has been done to your car but, you need to do more time looking through here to save yourself totally unnecessary pain;
http://www.skylinesaustralia.com/forums/in...showtopic=66556
good luck mate
or you could rebuild the gts-t. redo the electronics. re-do hoses etc. new suspension. give it a paint job and it will feel brand new. mayb some series 2 seats or something. even if you buy a wrx... eventualy youll run into the same problems... so just fix what ya got and make it new
my 2 cents
I think you'll have a hard time selling it if it's running like a bag of shit. someone will buy it off you for cheap, spend $500 bucks on it and have a great car. take it to someone who knows what they're doing. it will be worth your money.
jezzerr is on the money
no one will buy it if they have test drove a few nice ones
fix yours properly leak down test timing belt injector clean you know champ tlc
wat mods do you have
james
Edited by Miller the hoon
How many Kms has it done, a friend of mine has a S1 R33 and it had done about 89,000 and he bit the bullet and got the 100,000 Kms service done and made a HUGE differance to how his car ran, he then added a PFC about 3 weeks later and it felt like a new car. He now beats all standard WRXs and he is now looking at suspension and a turbo upgrade.
Keep the Line dont go to a WRX as they have just as many problems as skylines.
I have raced a few ranging from 99-03 and havent lost a race. Stayed with a 05 STI aswell. Dont sell the line dude, fix your problems and enjoy it!
thanks a lot guys,
Yeah it is just me trying to save a bit of coin and use the forums to pinpoint the dramas and fix it cheap, as I have spent 5k on new motor etc in the last couple of months.Also my dad is a mechanic and has his own business but even he is ready to incinerate it with me. But im thinking of taking it to 'garage hiramitsu' on the Gold Coast as apparently they are quite good.
Im sure if it ran like it used to with the old motor and a few more mods and the 2k stereo ive got waiting to go in id love it again. Its just at the moment i look at it and cringe because it is sending me broke! lol
James,
Car has a hybrid front mount, k and n pod, 3.25 inch exhaust(only cat-back), exedy brass button clutch, kyb mountain climb struts and some sort of jap springs-poly'castor rod bushings, 400 r front bar, gtr sideskirts-pods-boot spoiler, 350z rims,
Car is brand new windscreen to the front panels and bonet and headlights, front bar. Thats another reason i do like the car. Ill have to get some pics up. Not being biast, but looks wise it is one of the better 33's ive seen on the Gold Coast
Thanks guys I was considering buying a rex?! what an idiot!
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
