I realise there are many various types available,
are there any atmo's that don't cause the car to stall, etc, etc
In Short No.
The lack of air on the intake IS the reason why it stalls.
Throw a pod on and it'll make a sound.
or
Block off the stock BOV with a pod andf it'll make a cooler sound.
or
Forget about sound and concentrate on other things like CAI, Hi Flow CATS and FMIC.
Moot
No benefit.
Much the same way as there is no benefit with running a atmo BOV. How about you tell us why you want a atmo bov?
If it's for something other than then rice factor then perhaps we can collectively think of another solution for your untold troubles.
Moot
the only way to make the stock bov vent to atmo properly is to get a one way valve on to the venting end.
this can be done.
if you really want to, measure the OD of the bov outlet then go to a plumbing store with those measurements and look for a one way valve to fit over that OD. so on idle when the bov is open, air will not be sucked in from there.
NOTE: this will alow you to get the sound you want but it doesn't prevent the running rich and so forth..
The car came with the atmo BOV on it, just trying to work out whats better.
I see....
So why do you want to turn a stock BOV (which you don't have) into an atmo one?
Trust me...the stock one is loud!!!! If you wanna make it louder then get a metal intake pipe.
The stock one is ten times better on a stock ECU. If you get a power FC then go atmo all the way
End of Story.
it would be very silly to change to a map sensor ecu just for a stupid BOV.
but yes it would work a bit better. you cannot get djetro rb20 but you can get an rb26 djetro working on an rb20 to achieve the same goal
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
