0secs when i take off usually, 1-0mins stopping
any cars its a good idea to run up and run down, but still, they're modern cars I am sure they can handle it. Oil can start to solidify in the turbo apparently if you just turn straight off, but i'm not sure how true that is... and whether for daily driving (not a track) that it matters who knows.
Anybody regularly pull turbos off skylines regularly? Do you regularly find bad oil deposits?
sometimes i let mine idle for a bit and sometimes i dont. when i dont i always drive it soft. however if im running late to work or something i'll run outside and start it up and come back about 7 minutes later then i can drive it harder sooner and get to work on time.
I usually drive off (reverse out of driveway) within about 10 secs of (cold) starting the engine, but never pull more than about 3000 rpm, and never pull boost, until the engine is up to full operating temp.
personally i do what most do, start, wait a min or two then drive off and stay off boost till water temps get +60degrees celcius
i read in a recent Merc users guide for a car that i dont remeber, and it said
"dont let the car idle to warm it up in the one spot...start the engine, let idle for a min, then drive but keeping the rpm's low. this is a more effective method of warming up all engine components"
or something along those lines
In the morning I'll start my car, put the turbo timer on 5 mins, then lock and arm the car (car alarm detects TT). I never usually let it warm up for less than 5 mins, but about 2 mins cold start is ok. If the car was driven within a few hours, about a minute does it for me.
As for cooling down, i leave it for 1 min, or if I have REALLY been caning it, about 2 mins.
I dont give it any stick either until temp is half way, and oil preasure is down to 2bar on idle.
This was the approach I took on my R31, and after 7 years (and i used to cane the crap out of it when it was warm), I never once got anything repaired (except fan clutch), and compression was almost the same as it was when i bought it. Hardly ANY noticable power loss.
What i do may be overkill, but if you really take care of your car, chances are it will be a lot lighter on your wallet!
my 2c
do you drive a merc? :alien:
Thats b/c some people assume that if you warm it up for 10 -15 mins at home in the garage, its ok to thrash it afterwards.... you also need to consider the gearbox, the diff etc. I agree 1 or 2 mins is sufficient, but then you still gotta take it easy...
I got a mate who couldn't give a rats arse for his R31, in the morning he starts the car with the clutch in, and ready in first gear. As soon as it has cranked over, he floors it and lets one rip down his street to warm it up. I keep telling him off, but he seriously couldn't care less for his car...
He also does this b/c his choke is wrecked, so this prevents his car from stalling at the first set of lights...
I normally kick it over as soon as I get in the car, then let it idle while I get myself ready - normally between 30 and 60 seconds. Then not go over 3K RPM until the engine is nice and toasty. Depending on how I drive it, I may turn it straight off (like a trip up the road to the shops) or leave it running for up to 7 minutes (long trip on the open road draging off everything I come across). Normally I leave it for about 3 minutes after an average drive. Listen to some music, check the mailbox, clean off the mats, or just admire my toy :-)
Guest nismogtsx
Same as the rest.... Let it idle for a minute while i get my glasses out and light up a smoke... then im ready... But i find the car produces more power prior top the TT reading an air/fuel ratio...
This week end im gonna d/c the O2 sensor from the ECU and see what happens.... Should go hard but i believe it will chew fuel...
Might be a good drag racing technique....
Will post the results...
yeah-i read in a bmw manual that the most efficient way to warm up the car was just to drive off, going easy on the accelrator for about 5 mins-seems easy enough to me, and better than sitting round waiting for a car to warm up... so yeah, just stay off boost (if u can help it) for like five mins
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
