R33 Thermostat
Guy's follow the bottom radiator hose up to where it joins the motor,,,thats the stat cover,,,3 bolts from memory.
The stat is the same as a VL 3.0L,,,Nissan Part No is 21200-42L05 and it fits all R33's.
Neil.
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-195749
  • 6 years later...
ok guys, there are a few things to know here:
firstly for the money and time saving just get a genuine nissan one from nissan parts. they are around $50-60.
second, if you want a 'tridon' one...the part number is TT268-170. this is the 77deg one. there is an 85 deg one...dont get this!
lastly if you want to waste money, get the nismo one but these are over $100 if not closer to $150 and open at 67 or so deg.
you will also need gasket goo for this as there is not a norml gasket there. i use the blue stuff...works perfect!
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-4606827
bellow i attached instructions from the RB engine manual.
view order 3 then 1 then 2. (sorry i didnt rename)
as the above people have said use either the tridon or stnd nissan one.
tridon will set you back about $28 and its one of the good cheapies.
make sure the jiggle pin is pointing to the top of the motor.
for gasket sealent i recomend a product from loctight.
Its a silicone based gasket goo, its loctight blue something or other.
It's the ducks nuts, will come in handy down the track to.
let us know how you go.
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-4606908
was reading a thread recently and a workshop operator said he'd been through a bunch of tridon thermostats that were crap, and caused problems.
just use the nissan one. also there is no reason to use a lower temperature it will NOT help you, it just means your car won't get up to temp and you'll lose fuel efficiency.
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-4608777
  • 2 years later...
hi guys on my r33 gtst 1993 it has a braided cable that runs down threw the chassis and comes out next to the exhaust, and theres something that attaches to that which im not sure what it is or where to get another one because i scraped going over a speed hump and its pulled it out and stuffed it and i think its shorting out, my thermostat light is staying on and check engine also comes on itermitently. Any help on where i can get another one of these, and or what it is would be good cheers
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-6110663
  • 2 years later...
Disconnect it, it's useless. Pull out your passenger seat and delete that sensor
https://www.sau.com.au/forums/topic/11244-r33-thermostat/#findComment-7274366
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
