i have done a quick search for how to get rid of the speed limiter as i hit it 4 times on the way home from work today(isolated country road) at 185klms an hr at 4500 rpm ish. i would like to get rid of this and actually see what the thing can do.
are you able to bridge this out or isloate it in some way so i can wind it out and pass my mates modified ss crumpledorre above these speeds?.
before the hounding starts i am an ex-racer of bikes and karts and i know the road etc. and you can see for miles if there is anything/one coming the other direction.
a group of us use the road for testing of race cars/bikes all the time and the best part about it is that either end of the strip there is about 20k's of tight mountain roads that get the tyres nice and sticky too.
Yeh, I was cruising on the speed limiter for about half an our the other day.
Its really annoying, because i know i could have made even better time :thumbsup:
Id be interested to know how to do this too. I know there is a speed cut defender, but it must be a lot more simple than that.
Went to a dyno shootout last weekend and both skylines maxed out at 150/153 HP. I believe it may have been the speed limiter kicking in.
You could hear them making good power, then at little over half revs they would develop what sounded like a missfire.
Q. I've only been upto 170 so I dont know exactly what it feels like - is it a missfire or does it electronically overide the accelerator like it does in a coach/truck?
(170...b/c it was only an SS dunnydoor, so not much of a race, plus we were on our way to church)
Anyhow, if anybody knows which wire to snip to disable the limiter then I would be glad to hear about it.
It feels... like a speed limiter...lol
Its not like a rev limiter, think of when you are playing Gran Turismo and your car is maxing out at like 400km/h and its like, a slow increase in revs, then a drop, then a rise, then a drop. Quite a slow process.
Its not very harsh either.
how yaz doin? i have the same problem i've found the solution well if your running an rb20det have not tried it yet as been busy but hofully will have it done by this week end...
Remove the speed limiter: Cut wire #53 on the ECU harness to disable the 180 kph speed cut. The wire is yellow/green with a silver trace. Insulate the bare ends with tape. There has been talk that this effects the hicass, but from what i've seen posted around the net driveability of the car is not changed,
Re: Speed Limit Defence Cut.
If you cut wire 53 all it does it prevent you from exiting the HICAS DIAGNOSTIC mode… Its therefore better to place this speed cut on a switch so you can still exit easily.
thanks to www.rb20det.com for this great piece of advice.
I've hit the limiter a few times as well,it's a pain in the arse.
I wouldn't advise just cutting pinouts on the ecu. besides just putting fault codes into it,you may lose the dash's speedo display,or even gears,as the gearbox ecu may no longer receive speed informaton...
it is much safer,although more expensive to fit something to rectify the problem. either a power fc to do everything,or an interceptor to cancel the speed cut like an apexi RSM,HKS SCD,or a pivot SML-M.
I have the pivot speedo/timer/speed cut eliminator on hand,and will fit it when I get time. will let you know results if you like.
Edited by fergo308
I would also not advise cutting the wire, or doing anything with the speed limiter. if you're ever in an accident and the car is inspected by the police and they find the speed limit wire cut they'll void your warranty and rego. i wouldn't want that to happen to anyone here
You can 't do that on an auto the ECU doesn't know the speed to change gear.
Speed Cut Defeater/Defender/Defencer ($150 from Nengun)
http://www.nengun.com/catalogue/product/759
What they do is allow normal (accurate) speed readings to get to the ECU up to 170 kph, so the gear changes etc are as per normal. Over 170 kph they limit the outgoing signal to the ECU to 170 kph, so the ECU never sees 180 kph and hence no speed limiter action. This doesn't effect gear changes as we should be well and truly in top gear at 170 kph.
:) cheers :)
Edited by Sydneykid
wow im amazed the last time i posted something like that on a forum i may as well got told that i am very naughty and that i should go to my room! hhaahah good to see that i am not the only one to want to get rid of the pesky limiter.
as it was i got to around 4500rpm in top (5sp manual) when it kicked in at a little past the 180 mark, so would be interested to find the end of its rope so to speak.
this is with a stock engine/driveline in a series2 only mods so far are koni suspenders,lowered springs and gtr rims.
i would like to see what it will do before i put a boost control and cooler on it.
if anyone on here has done so in a series2 man. i would like to hear so i know what to expect when its modified further.
Don't count on the speedo being accurate, mine was reading 170 kph at a genuine 164 kph with almost brand new 225/50/16 tyres. As they wear it would become even more optimistic. With the larger diameter of the 245/40/17's it's a bit more accurate.
:P cheers :(
Edited by Sydneykid
PowerFC = no speed limiter, still the fastest I've had her is only about 130-140kph, obviously on private roads, as I dont see the point in taking a road car beyond that, I dont have a deathwish, not stating you guys do, but most QLD roads just arent built to allow a car to travel at those speeds safely, they are just not smooth enough in my opinion to safely travell at 150kph+ speeds for lengthy amount of times, well my opinion!
I think you're exactly right. unless you want to drag/race the car (which stageas aren't built for) then you don't need to remove the limiter. i hit 160 along my parents private road whenever i go home to Bathurst, but other than that i don't ever get much above 120 (maybe 130 on the hume)
No I think Rockhampton has the crappiest roads in Australia! :( But yeah the only decent road I would trust to go over the 140kph for lengthy periods of time would be the new section of the M1, from Beenleigh to Nerang, other than that the national highway is a joke compared to other contries I've driven in. Mainly because Australia's population is so sparse I beleieve there just isnt the funding to keep them in the condition they should be. Although Canada relatively has the same population, maybe a couple of million more, and they have some great road infrastructure.
Anyway I have tottally gone off topic and am ranting like an old man.... back in my day............ :) Back on topic now.
Pivot speed Meters go for between $90 and $150 online. Check out ebay or modyourcar.com
These will both remove speed limiter (safely, without HICAS issues) and read up to 350km/hr.
Also gives fairly accurate 0-100,200,300 and 400 metre times
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
